Hi i need firmware for EG18-EA modem. This modem is in mikrotik lhgg lte 18. Latest revision of firmware is EG18EAPAR01A13M4G i need newest or this same firmware, because soft is maybe broken?
Dear Customer,
I have sent the requested firmware through email. Please check there.
Hello fazrulredzuzn,
I currently have EG18NAPAR01A06M4G_01.008.01.008 firmware for EG18-NA modem Can you kindly send me the newest for EG18-NA modem ?
Dear Customer,
The firmware that you are having now is the latest firmware for EG18-NAPA.
Hello, I currently have EG18NAPAR01A06M4G_01.007.01.007.
Can you send me the newest?
Dear Customer,
I have sent the latest firmware requested through email. Please check there
Hello @fazrulredzuan,
Sorry for the mention. Could you please check whether an older firmware package or DFOTA downgrade package is available for my EG18-EA modem?
Current version:
EG18EAPAR01A13M4G_01.300.01.300
I am using a MikroTik Chateau LTE18 ax and after updating to A13 I started having LTE connectivity issues. I would like to test the previous stable A12 release.
If possible, could you please send:
- EG18EAPAR01A12M4G_01.001.01.001
or - any available DFOTA package for A13 → A12 rollback.
Thank you very much for your help.
Hi Alex,
Unfortunately, you cannot downgrade from A13 to A12 anymore as it could harm your module. Now the only available A12 firmware is EG18EAPAR01A13M4G_01.001.01.001 and it is not feasible to downgrade.
Regards,
Доброго времени суток, не могли бы Вы прислать прошивку EG18EAPAR01A13M4G_01.003.01.003. Сейчас установлена EG18EAPAR01A13M4G_01.300.01.300 к сожалению сеть от операторов в станах СНГ она не получает.
Dear Customer,
May I know if is there any issue with the current latest firmware that you have in the module? If yes, you can let me know.
Здравствуйте. У меня имеется 2 mikrotik atl lte18 kit
В первом устройстве установлен модем EG18-EA Ревизия EG18EAPAR01A13M4G с прошивкой EG18EAPAR01A13M4G_01.003.01.003 - это устройство работает корректно(определяет сим карту и получает сеть от оператора)
Во втором устройстве установлен модем EG18-EA Ревизия EG18EAPAR01A13M4G с прошивкой EG18EAPAR01A13M4G_01.300.01.300 - это устройство не видит сеть оператора (сим карту определяет видит частоты, через cell monitor видит сети операторов, но саму сеть(интернет) не получает) слот под сим карту и сама сим карта рабочии, пробовал на 4х операторах.
в связи с этим хотелось бы на втором устройстве откатить прошивку модема до версии EG18EAPAR01A13M4G_01.003.01.003. Заранее благодарю.
Dear Customer,
I understand there is an issue with your module. But unfortunately, EG18EAPAR01A13M4G_01.300.01.300 is the latest firmware for the module and cannot be downgraded to the older version than .200 as it could harm your module.
Another way is, can you help to provide me AT logs of the failed operation, design file of your project or any related information. I could help to analyze the issue. If the contents of your project is highly sensitive to be shared here, we can communicate through email,
Hello.
I have an EG18-EA with firmware EG18EAPAR01A13M4G_01.300.01.300 and I’m having problems with LTE network registration. The modem keeps searching and sometimes cannot register at all. The same SIM card works normally in another LTE modem.
I would like to try downgrading to EG18EAPAR01A13M4G_01.200.01.200.
Could you please send me a DFOTA package for downgrading from 01.300.01.300 to 01.200.01.200 or the full 01.200.01.200 firmware? Please also let me know how to install it.
Thank you.
Hi, Wanxin here. I have sent an email to your inbox. Please check it. ![]()
Model: EG18-EA
Revision: EG18EAPAR01A13M4G
Current firmware: EG18EAPAR01A13M4G_01.300.01.300
Host: MikroTik
SIM operators: MCI (Hamrah Aval) and Irancell, Iran
The module detects the SIM correctly (CPIN: READY), but it cannot register:
CEREG: 2,4
QNWINFO: No Service
QENG: LIMSRV
The same SIM cards work normally in a phone.
Please provide the official compatible firmware/DFOTA package for A13,
preferably EG18EAPAR01A13M4G_01.201.01.201 or the currently recommended
regional firmware, together with QFlash/QFirehose and flashing instructions.
Hi, Wanxin here. I have sent an email to your inbox. Please check it, thank you.
Hi, I have the exact same case — EG18-EA in a MikroTik LHG LTE18, firmware
EG18EAPAR01A13M4G_01.300.01.300, SIM detected (CPIN: READY) but no
registration on local networks.
Could you please also send me the EG18EAPAR01A13M4G_01.201.01.201 package
(with QFlash/QFirehose and instructions)?
Thank you.
Hi, I have sent the firmware and flashing instructions to your inbox, pls chk
Hello.
I have the same problem as Morario.
I have 2 EG18-EA with firmware EG18EAPAR01A13M4G_01.300.01.300 and I’m having problems with LTE network registration. The modem keeps searching and sometimes cannot register at all. The same SIM card works normally in another LTE modem.
Thank you.
Hello @morario,
I have exactly the same problem with my Quectel EG18-EA in a MikroTik ATL LTE18 kit.
My modem:
* EG18-EA A13
* Current firmware: EG18EAPAR01A13M4G_01.300.01.300
* MikroTik ATLGM
* RouterOS 7.20.8
* SIM operator: MegaFon, Russia
The modem detects the SIM correctly, but it cannot register on the network:
* CPIN: READY
* CEREG: 2,4
* QNWINFO: No Service
* MikroTik LTE status: denied
I saw that you requested the 01.200.01.200 firmware from Quectel and they sent it to you by email.
Could you please share the firmware package with me, if it is allowed, or tell me exactly what files they sent you?
I am especially looking for:
I already have QFlash and QFirehose, so I only need the correct firmware package.
Thank you!
