Using a EG25-G module with ModemManager, the USB connection is sometimes lost when the host wakes up from sleep. When that happens, only AT commands work, but QMI commands always time out.
[ 641.017032] Disabling non-boot CPUs …
[ 641.021756] CPU1: shutdown
[ 641.024586] psci: CPU1 killed (polled 0 ms)
[ 641.033510] CPU2: shutdown
[ 641.036402] psci: CPU2 killed (polled 0 ms)
[ 641.044610] CPU3: shutdown
[ 641.047517] psci: CPU3 killed (polled 0 ms)
*** Sleep for some time ***
[ 641.055520] Enabling non-boot CPUs …
[ 641.060534] Detected VIPT I-cache on CPU1
[ 641.064586] arch_timer: CPU1: Trapping CNTVCT access
[ 641.069555] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
[ 641.076896] CPU1 is up
[ 641.079922] Detected VIPT I-cache on CPU2
[ 641.083950] arch_timer: CPU2: Trapping CNTVCT access
[ 641.088913] CPU2: Booted secondary processor 0x0000000002 [0x410fd034]
[ 641.096095] CPU2 is up
[ 641.099114] Detected VIPT I-cache on CPU3
[ 641.103142] arch_timer: CPU3: Trapping CNTVCT access
[ 641.108104] CPU3: Booted secondary processor 0x0000000003 [0x410fd034]
[ 641.115280] CPU3 is up
[ 641.118480] sunxi-rsb 1f03400.rsb: RSB running at 4000000 Hz
[ 641.567816] PM: dpm_run_callback(): pm_generic_resume+0x0/0x44 returns -1
[ 641.574629] PM: Device mmc1:0001:1 failed to resume async: error -1
[ 641.681650] usb 3-1: reset high-speed USB device number 5 using ehci-platform
[ 641.847706] option1 ttyUSB0: GSM modem (1-port) converter now disconnected from ttyUSB0
[ 641.855779] option 3-1:1.0: device disconnected
[ 641.860611] option1 ttyUSB1: GSM modem (1-port) converter now disconnected from ttyUSB1
[ 641.868674] option 3-1:1.1: device disconnected
[ 641.873481] option1 ttyUSB2: GSM modem (1-port) converter now disconnected from ttyUSB2
[ 641.881548] option 3-1:1.2: device disconnected
[ 641.886394] option1 ttyUSB3: GSM modem (1-port) converter now disconnected from ttyUSB3
[ 641.894457] option 3-1:1.3: device disconnected
[ 641.900446] OOM killer enabled.
[ 641.904864] Restarting tasks …
[ 641.908522] option 3-1:1.0: GSM modem (1-port) converter detected
[ 641.925293] done.
[ 641.928652] usb 3-1: GSM modem (1-port) converter now attached to ttyUSB0
[ 641.935778] PM: suspend exit
[ 641.944364] option 3-1:1.1: GSM modem (1-port) converter detected
[ 641.953758] usb 3-1: GSM modem (1-port) converter now attached to ttyUSB1
[ 641.967188] option 3-1:1.2: GSM modem (1-port) converter detected
[ 641.974514] usb 3-1: GSM modem (1-port) converter now attached to ttyUSB2
[ 641.986097] option 3-1:1.3: GSM modem (1-port) converter detected
[ 642.005809] usb 3-1: GSM modem (1-port) converter now attached to ttyUSB3
I’ve installed latest firmware (EG25GGBR07A08M2G) when noticing the release notes state “Solved the problem for USB disconnection” twice, but the problem still occurs.
How can I troubleshoot this issue?
