We’ve been using the EG 25G module in India, and while it works perfectly when shipped to Europe, we’ve experienced frequent disconnections when used in India. We were recently advised to use a 5dB antenna, which initially improved the performance. However, some modules are still experiencing connection issues even with the 5dB antenna. Notably, the modules are responding to SMS commands. Here’s the response we received from the SMS INFO and Google: The GSM signal is strong, and the APN is set to airteliot.com.
We believe that if we can lock the band to LTE, 4G, and 2G, it may start working as it has a much broader band available. Is there an AT Command available to do that?
000012
IMEI:86770XXXXXXXX
APN:Airteliot.com
Active Int:60
Normal Int:300
Standby:600
GSM:20
GPS:1
Sat:4
MainPwr:1
IGN:1
GPRS:PDP act
Flash:175
