Please advise what should be configured on the modem for ECM mode to work.
The question is related to EC/EP/EM series.
I’ve got this mode working on EP06 and EC25 without any special effort from my side, others reported successful testing on EC25 (again) and EM12. At the same time I saw reports from EM06 and EC200T owners saying that those modems refused to work in ECM mode. Refused means no traffic to/from the Internet.
In all the cases the mode was properly set (AT+QCFG="usbnet" +QCFG: "usbnet",1), host system successfully obtained the IP address from the modem and the modem itself had successful network registration and, finally, connection was established that is confirmed by the IP address obtained from the carrier:
Dear Jfrog,
For different module, if you want to use ECM mode, you need to set the following command:
AT+QCFG=“usbnet”,1
Please note that different module have different mode by default. For EC25 module, the default is NDIS with AT+QCFG=“usbnet”,0; for EM/EP module the default is MBIM; and only EC200T module is ECM by default. Thanks!
