I have this board : EC800GCN Hua series DTU development board. I would like to use micro python programming.
The documentation points to
I tried flashing the available firmware on the website using qpycom, but was not successful. Kindly help with to provide the firmware to transition from transparent mode to python firmware mode.
My Email ID is harishh@gmail.com
May I ask which firmware version you downloaded? Would you please send AT+GSN via the AT port? I need to confirm the factory firmware of the module.
at
ati
EC800KCN_LC
Revision: LTE01R07A14_C_SDK_A
at+gsn?
ERROR
at+gsn
ERROR
at+cgsn
“867244XXXXXX473”
Here is the complete output of the AT+CGSN
AT+CGSN
“867244089320473”
From the firmware version, you are using the QuecOpen scheme instead of the QuecPython scheme.
Which scheme do you plan to use going forward, QuecOpen or QuecPython?
the QuecOpen scheme uses C language for development.
商品详情, here is the link for reference. firstly, please let me know where I can find the configuration application mentioned. Secondly, if i have to use quecopen sdk, please share the procedure for download. Also, if the quecpython is available, I am trying both of them.
This should use a standard solution controlled via AT commands. The UE-D5401 configuration tool mentioned in the documentation is a third-party tool that can be downloaded from the Internet.
Once we do python programming as per the requirements, is there a way to disable/enable programming REPL/USB channels.
Dear customer
yes,suppport,please refer to the link below
