Could I please have documentation for the <<EC25EU: AT+QIMSCFG=“speech_codec”>> AT command?
hi ,
May I ask which version of Open you are using?
Thanks for sharing this information.
Hi, sure, here you are:
EC25EUGAR06A01M4G_OCPU_01.001.01.001_SDK
EC25
Revision: EC25EUGAR06A01M4G
@leon.bao Please assist in looking into this issue. The client is using the open version.
Hi,@riccardo.montagna
For the Open solution, we usually use APIs instead of the AT commands in the Standard solution. Therefore, the Open solution generally does not support most AT commands.
If you want to use AT commands, please select the Standard solution. If you wish to continue using the Open solution, please let me know which functions you want to implement, and I will send you the relevant API guide documentation.
Thanks.
Hi, I’m developing on existing device, It already support that command, adding a feature, but documentation provided is just a partial image of a doc.
I was asking entire doc file, if not possible to have here, I’ll continue without it
Thanks, regards
Currently, I have only found the following information regarding this command, and I hope it will be helpful to you.
thanks a lot, I already have that picture, is it entire command chapter? are there more examples or details of when command is applicable?
