EC25AFFAR07A08M4G_01.001.01.001 latest firmware
Looking for the latest firmware for the EC25AFFAR07A08M4G_01.001.01.001
I have a message from your bot, that’s it. No DM"s from you.
No message received. Second reminder. Thanks.
Can you provide a valid email address?
There is a valid email attached to this forum account. If you’re an admin, that should be visible to you.
I can see it, and I sent it to this mailbox. Please check whether it was intercepted by the mailbox as spam
It was. You should send firmware updates with an english-language subject line, as you are communicating with someone in english (I have not written any chinese characters to you).
That is why it ended up in spam.
I have another question: Flash was successful! Thank you. I have been reading the 300+ page Quectel PDF v2.0, and EC25-AF-FA_Firmware_Release_Notes_V0714_01.003.01.003 Release notes.
What commands modify the IPV6 portions of the RNDIS/ECM mode behaviour? On this openwrt device, the wwan6 alias is not getting an ipv6 address from the Quectel card. It was, directly after the flash. Once changing modes to ECM, then back to RNDIS, it stopped.
AT+QCFG=“usbnet”,3 # RNDIS
AT+QCFG=“usbnet”,1 # ECM
AT+QCFG=“usbnet”,3
AT+CFUN=1,1
were the commands used.
was the problem. As he did, I had I used a tty cable to directly wire into the EC25 card, to issue AT commands.
AT+QCFG=“usbauto”,0
AT&W
AT+CFUN1,1
fixed it. The /dev/ttyUSBx ports have returned, and it’s no longer stuck in RNDIS mode.
Commands like ‘AT+QCFG=“usbnet”,2’ had no effect, as long as “usbauto”,1
