Hi! I’m using an EC25 on a raspberry pi, it work great because i’m getting internet on it and i’m writing on this forum with this internet
So now i have setuped a webserver on port 8765 and i need to acces my webserver from distant computer through my LTE network, so i want to be able to go on any webbrowser and acces my webserver with my IP address. exemple: http://25.25.25.25:8765/
How can i setup my quectel EC25 to open the necessary port? Maybe with some at command?
Normally the IP address such as 25.25.25.25 as mentioned which is provided by the operator. It does not means it is a pulic address.
So from the outer side it cannot access the device with that IP.
The 25.25.25.25 that i wrote is just an example, actually my “real” external ip is 24.114.95.248
So there is no way to acces my webserver from the internet?
i’m actually running a camera on this device and want to acces the feed from my camera, maybe you have another suggestion on how i can proceed to have an acces to my camera feed?
Are you sure that the operator has provided you with the public IP address?
Possible solution:
The operator gives you the public IP address.
Use a third-party server.
