Ec25 sometime no connect to internet
Hello
I have a Ec25 module, a linux embedded system and I use GobiNet driver, quectel-CM
All works well but sometimes during a day the module never connect to internet for 2 o 3 hours and
I have the following log:
11-02_14:30:54:734] Find /sys/bus/usb/devices/1-1.2 idVendor=0x2c7c idProduct=0x125
[11-02_14:30:54:735] Auto find qmichannel = /dev/qcqmi0
[11-02_14:30:54:735] Auto find usbnet_adapter = usb0
[11-02_14:30:54:735] Modem works in QMI mode
[11-02_14:30:54:755] Get clientWDS = 10
[11-02_14:30:54:787] Get clientDMS = 11
[11-02_14:30:54:820] Get clientNAS = 12
[11-02_14:30:54:852] Get clientUIM = 13
[11-02_14:30:54:884] Get clientWDA = 14
[11-02_14:30:54:915] requestBaseBandVersion EC25EUXGAR08A08M1G
[11-02_14:30:55:044] requestGetSIMStatus SIMStatus: SIM_READY
[11-02_14:30:55:044] requestSetProfile[1] eav.tim.it/xxxxxxxxxx/xxxxxxx/1
[11-02_14:30:55:107] requestGetProfile[1] eav.tim.it/xxxxxxxxxx/xxxxxxx/1
[11-02_14:30:55:140] requestRegistrationState2 MCC: 222, MNC: 1, PS: Attached, DataCap: LTE
[11-02_14:30:55:172] requestQueryDataCall IPv4ConnectionStatus: DISCONNECTED
[11-02_14:30:55:172] ifconfig usb0 down
[11-02_14:30:55:176] ifconfig usb0 0.0.0.0
[11-02_14:31:51:861] requestSetupDataCall err = 0
[11-02_14:31:52:004] GobiNetThread exit
[11-02_14:31:52:004] qmi_main exit
[11-02_14:31:53:870] Find /sys/bus/usb/devices/1-1.2 idVendor=0x2c7c idProduct=0x125
[11-02_14:31:53:870] Auto find qmichannel = /dev/qcqmi0
[11-02_14:31:53:870] Auto find usbnet_adapter = usb0
[11-02_14:31:53:870] Modem works in QMI mode
[11-02_14:31:53:892] Get clientWDS = 11
[11-02_14:31:53:924] Get clientDMS = 12
[11-02_14:31:53:956] Get clientNAS = 13
[11-02_14:31:53:988] Get clientUIM = 14
[11-02_14:31:54:020] Get clientWDA = 15
[11-02_14:31:54:052] requestBaseBandVersion EC25EUXGAR08A08M1G
[11-02_14:31:54:180] requestGetSIMStatus SIMStatus: SIM_READY
[11-02_14:31:54:180] requestSetProfile[1] eav.tim.it/xxxxxxxxxx/xxxxxxx/1
[11-02_14:31:54:244] requestGetProfile[1] eav.tim.it/xxxxxxxxxx/xxxxxxx/1
[11-02_14:31:54:276] requestRegistrationState2 MCC: 222, MNC: 1, PS: Attached, DataCap: LTE
[11-02_14:31:54:308] requestQueryDataCall QMUXResult = 0x1, QMUXError = 0x5a
[11-02_14:32:09:347] requestQueryDataCall QMUXResult = 0x1, QMUXError = 0x5a
[11-02_14:32:24:388] requestQueryDataCall QMUXResult = 0x1, QMUXError = 0x5a
[11-02_14:32:39:428] requestQueryDataCall QMUXResult = 0x1, QMUXError = 0x5a
[11-02_14:32:49:998] ifconfig usb0 down
[11-02_14:32:50:004] ifconfig usb0 0.0.0.0
[11-02_14:32:50:180] GobiNetThread exit
[11-02_14:32:50:180] qmi_main exit
[11-02_14:32:53:008] Find /sys/bus/usb/devices/1-1.2 idVendor=0x2c7c idProduct=0x125
[11-02_14:32:53:009] Auto find qmichannel = /dev/qcqmi0
[11-02_14:32:53:009] Auto find usbnet_adapter = usb0
[11-02_14:32:53:009] Modem works in QMI mode
[11-02_14:32:53:027] Get clientWDS = 12
[11-02_14:32:53:060] Get clientDMS = 13
[11-02_14:32:53:092] Get clientNAS = 14
[11-02_14:32:53:123] Get clientUIM = 15
[11-02_14:32:53:155] Get clientWDA = 16
[11-02_14:32:53:187] requestBaseBandVersion EC25EUXGAR08A08M1G
[11-02_14:32:53:315] requestGetSIMStatus SIMStatus: SIM_READY
[11-02_14:32:53:315] requestSetProfile[1] eav.tim.it/xxxxxxxxxx/xxxxxxx/1
[11-02_14:32:53:380] requestGetProfile[1] eav.tim.it/xxxxxxxxxx/xxxxxxx/1
[11-02_14:32:53:412] requestRegistrationState2 MCC: 222, MNC: 1, PS: Attached, DataCap: LTE
[11-02_14:32:53:443] requestQueryDataCall QMUXResult = 0x1, QMUXError = 0x5a
[11-02_14:33:08:483] requestQueryDataCall QMUXResult = 0x1, QMUXError = 0x5a
[11-02_14:33:23:491] requestQueryDataCall QMUXResult = 0x1, QMUXError = 0x5a
[11-02_14:33:38:531] requestQueryDataCall QMUXResult = 0x1, QMUXError = 0x5a
[11-02_14:33:49:137] ifconfig usb0 down
[11-02_14:33:49:143] ifconfig usb0 0.0.0.0
[11-02_14:33:49:316] GobiNetThread exit
[11-02_14:33:49:316] qmi_main exit
What is the error 0x5a ?
CREG, COPS and CSQ are all ok but the internet connection dosen’t start.
This does not seem like a configuration or software problem because without changing anything at some point the connection restarts
Hello, I also think it is not the configuration or network problem according to your description. Now we have a new firmware version, and some network problems have been optimized. Do you need to upgrade to the new version to confirm whether the problem has been solved? If necessary, please provide your email address and I will send you the new version.
Hello
my mail is anna.scuderi@connetweb.com
Can you send me the instructions for install the upgrade on the module?
Anna
Hi,I send it to you,Please check.
Thank you but are you sure the is the correct version for my module Ec25-e ?
The version name is completely different from the previous one
EC25EUXGAR08A08M1G
Request for EC25-EUX standard firmware without MCC lock (EC25EUXGAR08A08M1G or latest generic)
dsadcikov54@gmail.com
Hi, I have sent the latest firmware to your inbox, pls check, thanku.
Hello, I have EC25-EUX-GR module (current: EC25EUXGAR08A15M1G). Downgrade to A09 causes CFUN:5 (radio failure). I need firmware EC25EUXGAR08A11M1G_20.003.20.003 for compatibility testing. Please send to
I’m an individual developer/hobbyist. I bought this module from the secondary market for personal IoT projects. I cannot provide company details. I need firmware A11 to fix CFUN:5 after accidental downgrade. Please help if possible."
Hi, I have sent the firmware to your email, pls chk
