I am using EC25 as LTE/3G internet interface with qmi mode, I would like to know is there any way to reduce it’s MAX TX power.
Dear Yoones,
For your issue, could you tell us why you want to reduce the MAX TX power ? Normally, it is no need to adjust the TX power, the module will adjust it automatically according to signal quality, which means that when the signal quality is good enough, the module will reduce the TX power, otherwise it will improve it. But the Max TX power upper is limited to 23dbm. Thanks!
