How can I play a sound file when calling and save incoming voice call to the file like answering machine on QuecOpen
Dear Vahid,
For your issue, please check the following document. Thanks!
Quectel_WCDMA<E_Audio_Design_Note_V1.2_20170723.pdf (1.5 MB)
If you want to play a file when calling, please check the following command in the above document. Thanks!
Thanks Kyson.
Is there any way to read stream of audio and send stream of audio with C API?
If you want to read the audio, you also can check the file that i have sent to you. And about the C API, you need to develop it by yourself. Thanks!
Hello, i need these also, thanks
