Dear forum,
I am using a few EC25. In the area I am located most cell phone provider offer higher quality voice calls.
When using the EC25, document quectel_eg060keg120k_series_voice_over_ttyusb_application_note_v1-0.pdf tells to use sampling rate (rate) to 8 kHz, and format (format) to 16-bit linear.
I saw that competitor SIMCOM on similiar placed products (SIM7600) supports also 16 kHz sampling rate.
Through this I expect the audio quality should increase. If I sent higher quality audio between the host controller to the lte modem module, the modem module probably also use a higher quality for the modem connection to the provider if offered.
Do you plan to support higher quality audio on Quectel EC25 series?
Best regards
Chang
