I design LAN connection on EC25 with DP83867. Does Quectel support DP83867 on EC25 ?
I read on document EC25 only support AR8033 (attached image), is it right ?
Hi Thanhtinbk
EC20 currently only supports AR8033 PHY chip, you need to modify your design, QUECTEL is sorry for this.
Best wishes
Hi Felix, thank you so much. Does EC25 is also only support AR8033 too ? I am using EC25.
Hi
The EC25 standard module only supports AR8303. The openlinux version supports self-adapted driver, thus supporting DP83867 .
Best wishes
Your chip doesn’t support SGMII. It supports MII,RGMII, GMII. EC25 has SGMII protocol for ethernet. Texas has SGMII PHY’s etc: DP83867CS
