Summary
U-Boot 2019.01 (Sep 25 2019 - 10:28:26 +0800)
CPU: Zynq 7z020
Silicon: v3.1
Model: SFDK zynq-ICVC board
DRAM: ECC disabled 768 MiB
NAND: zynq_nand_init: nand_scan_ident failed
ZYNQ NAND init failed
0 MiB
MMC: mmc@e0100000: 0
Loading Environment from SPI Flash… Invalid bus 0 (err=-19)
*** Warning - spi_flash_probe_bus_cs() failed, using default environment
In: serial@e0001000
Out: serial@e0001000
Err: serial@e0001000
Net: No ethernet found.
Hit any key to stop autoboot: 0
Error: “bootcmd_mmc” not defined
switch to partitions #0, OK
mmc0 is current device
Scanning mmc 0:1…
no devices available
SCRIPT FAILED: continuing…
No ethernet found.
missing environment variable: pxefile_addr_r
No ethernet found.
No ethernet found.
!!! Booting cmd is deprecated (will be removed in 2020).
!!! Please move to distro bootcmd.
Device: mmc@e0100000
Manufacturer ID: 41
OEM: 3432
Bus Speed: 50000000
Mode : SD High Speed (50MHz)
Rd Block Len: 512
SD version 3.0
High Capacity: Yes
Capacity: 14.5 GiB
Bus Width: 4-bit
Erase Group Size: 512 Bytes
** Unable to read file uEnv.txt **
Copying Linux from SD to RAM…
3846936 bytes read in 226 ms (16.2 MiB/s)
10362 bytes read in 15 ms (673.8 KiB/s)
8680859 bytes read in 490 ms (16.9 MiB/s)
Booting kernel from Legacy Image at 02080000 …
Image Name: Linux-4.14.0-xilinx
Image Type: ARM Linux Kernel Image (uncompressed)
Data Size: 3846872 Bytes = 3.7 MiB
Load Address: 00008000
Entry Point: 00008000
Verifying Checksum … OK
Loading init Ramdisk from Legacy Image at 04000000 …
Image Name:
Image Type: ARM Linux RAMDisk Image (gzip compressed)
Data Size: 8680795 Bytes = 8.3 MiB
Load Address: 00000000
Entry Point: 00000000
Flattened Device Tree blob at 02000000
Booting using the fdt blob at 0x2000000
Loading Kernel Image … OK
Loading Ramdisk to 1f7b8000, end 1ffff55b … OK
Loading Device Tree to 1f7b2000, end 1f7b7879 … OK
Starting kernel …
Booting Linux on physical CPU 0x0
Linux version 4.14.0-xilinx (root@ll) (gcc version 6.2.1 20161114 (Linaro GCC Snapshot 6.2-2016.11)) #1 SMP PREEMPT Mon Sep 16 19:28:47 CST 2019
CPU: ARMv7 Processor [413fc090] revision 0 (ARMv7), cr=18c5387d
CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
OF: fdt: Machine model: Zynq ICVC Board
Memory policy: Data cache writealloc
cma: Reserved 16 MiB at 0x2f000000
percpu: Embedded 16 pages/cpu @ee9c7000 s34764 r8192 d22580 u65536
Built 1 zonelists, mobility grouping on. Total pages: 195072
Kernel command line: console=ttyPS0,115200 root=/dev/ram rw earlyprintk
PID hash table entries: 4096 (order: 2, 16384 bytes)
Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
Memory: 744292K/786432K available (6144K kernel code, 231K rwdata, 1560K rodata, 1024K init, 152K bss, 25756K reserved, 16384K cma-reserved, 0K highmem)
Virtual kernel memory layout:
vector : 0xffff0000 - 0xffff1000 ( 4 kB)
fixmap : 0xffc00000 - 0xfff00000 (3072 kB)
vmalloc : 0xf0800000 - 0xff800000 ( 240 MB)
lowmem : 0xc0000000 - 0xf0000000 ( 768 MB)
pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
modules : 0xbf000000 - 0xbfe00000 ( 14 MB)
.text : 0xc0008000 - 0xc0700000 (7136 kB)
.init : 0xc0900000 - 0xc0a00000 (1024 kB)
.data : 0xc0a00000 - 0xc0a39d40 ( 232 kB)
.bss : 0xc0a39d40 - 0xc0a5feb4 ( 153 kB)
Preemptible hierarchical RCU implementation.
RCU restricting CPUs from NR_CPUS=4 to nr_cpu_ids=2.
Tasks RCU enabled.
RCU: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2
NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
efuse mapped to f0800000
slcr mapped to f0802000
L2C: platform modifies aux control register: 0x72360000 -> 0x72760000
L2C: DT/platform modifies aux control register: 0x72360000 -> 0x72760000
L2C-310 erratum 769419 enabled
L2C-310 enabling early BRESP for Cortex-A9
L2C-310 full line of zeros enabled for Cortex-A9
L2C-310 ID prefetch enabled, offset 1 lines
L2C-310 dynamic clock gating enabled, standby mode enabled
L2C-310 cache controller enabled, 8 ways, 512 kB
L2C-310: CACHE_ID 0x410000c8, AUX_CTRL 0x76760001
zynq_clock_init: clkc starts at f0802100
Zynq clock init
sched_clock: 64 bits at 333MHz, resolution 3ns, wraps every 4398046511103ns
clocksource: arm_global_timer: mask: 0xffffffffffffffff max_cycles: 0x4ce07af025, max_idle_ns: 440795209040 ns
Switching to timer-based delay loop, resolution 3ns
clocksource: ttc_clocksource: mask: 0xffff max_cycles: 0xffff, max_idle_ns: 537538477 ns
timer #0 at f080a000, irq=17
Console: colour dummy device 80x30
Calibrating delay loop (skipped), value calculated using timer frequency… 666.66 BogoMIPS (lpj=3333333)
pid_max: default: 32768 minimum: 301
Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
CPU: Testing write buffer coherency: ok
CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
Setting up static identity map for 0x100000 - 0x100060
Hierarchical SRCU implementation.
smp: Bringing up secondary CPUs …
CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
smp: Brought up 1 node, 2 CPUs
SMP: Total of 2 processors activated (1333.33 BogoMIPS).
CPU: All CPU(s) started in SVC mode.
devtmpfs: initialized
random: get_random_u32 called from bucket_table_alloc+0x1e0/0x220 with crng_init=0
VFP support v0.3: implementor 41 architecture 3 part 30 variant 9 rev 4
clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
futex hash table entries: 512 (order: 3, 32768 bytes)
pinctrl core: initialized pinctrl subsystem
NET: Registered protocol family 16
DMA: preallocated 256 KiB pool for atomic coherent allocations
cpuidle: using governor menu
random: fast init done
hw-breakpoint: found 5 (+1 reserved) breakpoint and 1 watchpoint registers.
hw-breakpoint: maximum watchpoint size is 4 bytes.
zynq-ocm f800c000.ocmc: ZYNQ OCM pool: 256 KiB @ 0xf0840000
zynq-pinctrl 700.pinctrl: zynq pinctrl initialized
e0001000.serial: ttyPS0 at MMIO 0xe0001000 (irq = 25, base_baud = 6249999) is a xuartps
console [ttyPS0] enabled
vgaarb: loaded
SCSI subsystem initialized
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
media: Linux media interface: v0.10
Linux video capture interface: v2.00
pps_core: LinuxPPS API ver. 1 registered
pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti giometti@linux.it
PTP clock support registered
EDAC MC: Ver: 3.0.0
FPGA manager framework
fpga-region fpga-full: FPGA Region probed
clocksource: Switched to clocksource arm_global_timer
NET: Registered protocol family 2
TCP established hash table entries: 8192 (order: 3, 32768 bytes)
TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
TCP: Hash tables configured (established 8192 bind 8192)
UDP hash table entries: 512 (order: 2, 16384 bytes)
UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
RPC: Registered named UNIX socket transport module.
RPC: Registered udp transport module.
RPC: Registered tcp transport module.
RPC: Registered tcp NFSv4.1 backchannel transport module.
Trying to unpack rootfs image as initramfs…
rootfs image is not initramfs (no cpio magic); looks like an initrd
Freeing initrd memory: 8480K
hw perfevents: no interrupt-affinity property for /pmu@f8891000, guessing.
hw perfevents: enabled with armv7_cortex_a9 PMU driver, 7 counters available
workingset: timestamp_bits=30 max_order=18 bucket_order=0
jffs2: version 2.2. (NAND) (SUMMARY) © 2001-2006 Red Hat, Inc.
io scheduler noop registered
io scheduler deadline registered
io scheduler cfq registered (default)
io scheduler mq-deadline registered
io scheduler kyber registered
dma-pl330 f8003000.dmac: Loaded driver for PL330 DMAC-241330
dma-pl330 f8003000.dmac: DBUFF-128x8bytes Num_Chans-8 Num_Peri-4 Num_Events-16
42c00000.serial: ttyUL1 at MMIO 0x42c00000 (irq = 45, base_baud = 0) is a uartlite
brd: module loaded
loop: module loaded
libphy: Fixed MDIO Bus: probed
e1000e: Intel® PRO/1000 Network Driver - 3.2.6-k
e1000e: Copyright© 1999 - 2015 Intel Corporation.
usbcore: registered new interface driver asix
usbcore: registered new interface driver ax88179_178a
usbcore: registered new interface driver cdc_ether
usbcore: registered new interface driver net1080
usbcore: registered new interface driver cdc_subset
usbcore: registered new interface driver zaurus
usbcore: registered new interface driver cdc_ncm
usbcore: registered new interface driver qmi_wwan
GobiNet: Quectel_WCDMA<E_Linux&Android_GobiNet_Driver_V1.5.0
usbcore: registered new interface driver GobiNet
ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
ehci-pci: EHCI PCI platform driver
usbcore: registered new interface driver cdc_wdm
usbcore: registered new interface driver usb-storage
usbcore: registered new interface driver usbserial
usbcore: registered new interface driver option
usbserial: USB Serial support registered for GSM modem (1-port)
chipidea-usb2 e0002000.usb: e0002000.usb supply vbus not found, using dummy regulator
ULPI transceiver vendor/product ID 0x0451/0x1507
Found TI TUSB1210 ULPI transceiver.
ULPI integrity check: passed.
ci_hdrc ci_hdrc.0: EHCI Host Controller
ci_hdrc ci_hdrc.0: new USB bus registered, assigned bus number 1
ci_hdrc ci_hdrc.0: USB 2.0 started, EHCI 1.00
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 1 port detected
i2c /dev entries driver
IR NEC protocol handler initialized
IR RC5(x/sz) protocol handler initialized
IR RC6 protocol handler initialized
IR JVC protocol handler initialized
IR Sony protocol handler initialized
IR SANYO protocol handler initialized
IR Sharp protocol handler initialized
IR MCE Keyboard/mouse protocol handler initialized
IR XMP protocol handler initialized
EDAC MC: ECC not enabled
Xilinx Zynq CpuIdle Driver started
sdhci: Secure Digital Host Controller Interface driver
sdhci: Copyright© Pierre Ossman
sdhci-pltfm: SDHCI platform and OF driver helper
mmc0: SDHCI controller on e0100000.sdhci [e0100000.sdhci] using ADMA
ledtrig-cpu: registered to indicate activity on CPUs
usbcore: registered new interface driver usbhid
usbhid: USB HID core driver
mmc0: Problem switching card into high-speed mode!
mmc0: new SDHC card at address 0001
mmcblk0: mmc0:0001 SD16G 14.5 GiB
mmcblk0: p1
pl35x_nand_cmd_function timed out
nand: No NAND device found
pl35x-nand e1000000.flash: nand_scan_ident for NAND failed
fpga_manager fpga0: Xilinx Zynq FPGA Manager registered
NET: Registered protocol family 10
Segment Routing with IPv6
sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
NET: Registered protocol family 17
Registering SWP/SWPB emulation handler
of_cfs_init
of_cfs_init: OK
RAMDISK: gzip image found at block 0
EXT4-fs (ram0): couldn’t mount as ext3 due to feature incompatibilities
EXT4-fs (ram0): mounted filesystem with ordered data mode. Opts: (null)
VFS: Mounted root (ext4 filesystem) on device 1:0.
devtmpfs: mounted
Freeing unused kernel memory: 1024K
EXT4-fs (ram0): re-mounted. Opts: data=ordered
Starting logging: OK
Jan 1 00:00:04 buildroot syslog.info syslogd started: BusyBox v1.26.2
Jan 1 00:00:04 buildroot user.notice kernel: klogd started: BusyBox v1.26.2 (2019-09-16 19:29:45 CST)
Jan 1 00:00:04 buildroot user.info kernel: Booting Linux on physical CPU 0x0
Starting mdev…
Jan 1 00:00:04 buildroot user.notice kernel: Linux version 4.14.0-xilinx (root@ll) (gcc version 6.2.1 20161114 (Linaro GCC Snapshot 6.2-2016.11)) #1 SMP PREEMPT Mon Sep 16 19:28:47 CST 2019
Jan 1 00:00:04 buildroot user.info kernel: CPU: ARMv7 Processor [413fc090] revision 0 (ARMv7), cr=18c5387d
Jan 1 00:00:04 buildroot user.info kernel: CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
Jan 1 00:00:04 buildroot user.info kernel: OF: fdt: Machine model: Zynq ICVC Board
Jan 1 00:00:04 buildroot user.info kernel: Memory policy: Data cache writealloc
Jan 1 00:00:04 buildroot user.info kernel: cma: Reserved 16 MiB at 0x2f000000
Jan 1 00:00:04 buildroot user.debug kernel: On node 0 totalpages: 196608
Jan 1 00:00:04 buildroot user.debug kernel: free_area_init_node: node 0, pgdat c0a39140, node_mem_map ee9f0000
Jan 1 00:00:04 buildroot user.debug kernel: Normal zone: 1536 pages used for memmap
Jan 1 00:00:04 buildroot user.debug kernel: Normal zone: 0 pages reserved
Jan 1 00:00:04 buildroot user.debug kernel: Normal zone: 196608 pages, LIFO batch:31
Jan 1 00:00:04 buildroot user.info kernel: percpu: Embedded 16 pages/cpu @ee9c7000 s34764 r8192 d22580 u65536
Jan 1 00:00:04 buildroot user.debug kernel: pcpu-alloc: s34764 r8192 d22580 u65536 alloc=16*4096
Jan 1 00:00:04 buildroot user.debug kernel: pcpu-alloc: [0] 0 [0] 1
Jan 1 00:00:04 buildroot user.info kernel: Built 1 zonelists, mobility grouping on. Total pages: 195072
Jan 1 00:00:04 buildroot user.notice kernel: Kernel command line: console=ttyPS0,115200 root=/dev/ram rw earlyprintk
Jan 1 00:00:04 buildroot user.info kernel: PID hash table entries: 4096 (order: 2, 16384 bytes)
Jan 1 00:00:04 buildroot user.info kernel: Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
Jan 1 00:00:04 buildroot user.info kernel: Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
Jan 1 00:00:04 buildroot user.info kernel: Memory: 744292K/786432K available (6144K kernel code, 231K rwdata, 1560K rodata, 1024K init, 152K bss, 25756K reserved, 16384K cma-reserved, 0K highmem)
Jan 1 00:00:04 buildroot user.notice kernel: Virtual kernel memory layout:
Jan 1 00:00:04 buildroot user.notice kernel: vector : 0xffff0000 - 0xffff1000 ( 4 kB)
Jan 1 00:00:04 buildroot user.notice kernel: fixmap : 0xffc00000 - 0xfff00000 (3072 kB)
Jan 1 00:00:04 buildroot user.notice kernel: vmalloc : 0xf0800000 - 0xff800000 ( 240 MB)
Jan 1 00:00:04 buildroot user.notice kernel: lowmem : 0xc0000000 - 0xf0000000 ( 768 MB)
Jan 1 00:00:04 buildroot user.notice kernel: pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
Jan 1 00:00:04 buildroot user.notice kernel: modules : 0xbf000000 - 0xbfe00000 ( 14 MB)
Jan 1 00:00:04 buildroot user.notice kernel: .text : 0xc0008000 - 0xc0700000 (7136 kB)
Jan 1 00:00:04 buildroot user.notice kernel: .init : 0xc0900000 - 0xc0a00000 (1024 kB)
Jan 1 00:00:04 buildroot user.notice kernel: .data : 0xc0a00000 - 0xc0a39d40 ( 232 kB)
Jan 1 00:00:04 buildroot user.notice kernel: .bss : 0xc0a39d40 - 0xc0a5feb4 ( 153 kB)
Jan 1 00:00:04 buildroot user.info kernel: Preemptible hierarchical RCU implementation.
Jan 1 00:00:04 buildroot user.info kernel: RCU restricting CPUs from NR_CPUS=4 to nr_cpu_ids=2.
Jan 1 00:00:04 buildroot user.info kernel: Tasks RCU enabled.
Jan 1 00:00:04 buildroot user.info kernel: RCU: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2
Jan 1 00:00:04 buildroot user.info kernel: NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
Jan 1 00:00:04 buildroot user.info kernel: efuse mapped to f0800000
Jan 1 00:00:04 buildroot user.info kernel: slcr mapped to f0802000
Jan 1 00:00:04 buildroot user.warn kernel: L2C: platform modifies aux control register: 0x72360000 -> 0x72760000
Jan 1 00:00:04 buildroot user.warn kernel: L2C: DT/platform modifies aux control register: 0x72360000 -> 0x72760000
JaJJaJJaJan 1 JJaJaJan 1JJaJaJaJan JaJaJaJan JaJaJaJan JaJaJaJan 1JJan JaJaJaJaJan JaJaJaJan JJJaJaJan 1 JanJanJanJanJanJanJaJaJanJaJanJanJanJanJaJaJanJanJanJanJanJanJanJaJaJaJamodprobe: can’t change directory to ‘/lib/modules’: No such file or directory
Initializing random number generator… done.
Starting network: ifup: can’t open ‘/var/run/ifstate.new’: No such file or directory
FAIL
检测到TF卡分区开始挂载,路径/mnt/tf
FAT-fs (mmcblk0p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
Jan 1 00:00:05 buildroot user.warn kernel: FAT-fs (mmcblk0p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
sh: can’t open ‘/mnt/tf/app.sh’
----- lx -----------
ifconfig: wwan0: error fetching interface information: Device not found
usb 1-1: new high-speed USB device number 2 using ci_hdrc
Jan 1 00:00:09 buildroot user.info kernel: usb 1-1: new high-speed USB device number 2 using ci_hdrc
option 1-1:1.0: GSM modem (1-port) converter detected
Jan 1 00:00:09 buildroot user.info kernel: option 1-1:1.0: GSM musb 1-1: GSM modem (1-port) converter now attached to ttyUSB0
option 1-1:1.1: GSM modem (1-port) converter detected
Jan 1 00:00:09 buildroot user.info kernel: usb 1-1: GSM modem (1-usb 1-1: GSM modem (1-port) converter now attached to ttyUSB1
Jan 1 00:00:09 buildroot user.info kernel: option 1-1:1.1: GSM modem (1-port) converter detected
Jan 1 00:00:0option 1-1:1.2: GSM modem (1-port) converter detected
9 buildroot user.info kernel: usb 1-1: GSM modem (1-port) converter now attached to ttyUSB1
Jan 1 00:00:09 buildroot user.info kernel: option 1-1:1.2: GSM musb 1-1: GSM modem (1-port) converter now attached to ttyUSB2
Jan 1 00:00:09 buildroot user.info keoption 1-1:1.3: GSM modem (1-port) converter detected
rnel: usb 1-1: GSM modem (1-port) converter now attached to ttyUSB2
Jan 1 00:00:09 buildroot user.info kusb 1-1: GSM modem (1-port) converter now attached to ttyUSB3
ernel: option 1-1:1.3: GSM modem (1-port) converter detected
Jan 1 qmi_wwan 1-1:1.4: cdc-wdm0: USB WDM device
00:00:10 buildroot user.info kernel: usb 1-1: GSM modem (1-port)qmi_wwan 1-1:1.4: Quectel EC25&EC21&EG91&EG95&EG06&EP06&EM06&BG96&AG35 work on RawIP mode
Jan 1 00:00:10 buildroot user.info kernel: qmi_wwan 1-1:1.4: cdc-qmi_wwan 1-1:1.4 wwan0: register ‘qmi_wwan’ at usb-ci_hdrc.0-1, WWAN/QMI device, 36:d2:0e:6d:15:32
Jan 1 00:00:10 buildroot user.info kernel: qmi_wwan 1-1:1.4: Quectel EC25&EC21&EG91&EG95&EG06&EP06&EM06&BG96&AG35 work on RawIP mode
Jan 1 00:00:10 buildroot user.info kernel: qmi_wwan 1-1:1.4 wwan0: register ‘qmi_wwan’ at usb-ci_hdrc.0-1, WWAN/QMI device, 36:d2:0e:6d:15:32
sh: Link: unknown operand
/root/quectel-CM -s ctnet &
[01-01_00:00:10:129] WCDMA<E_QConnectManager_Linux&Android_V1.1.45
[01-01_00:00:10:130] /root/quectel-CM profile[1] = ctnet///0, pincode = (null)
[01-01_00:00:10:131] Find /sys/bus/usb/devices/1-1 idVendor=2c7c idProduct=0125
[01-01_00:00:10:131] Find /sys/bus/usb/devices/1-1:1.4/net/wwan0
[01-01_00:00:10:131] Find usbnet_adapter = wwan0
[01-01_00:00:10:131] Find /sys/bus/usb/devices/1-1:1.4/usbmisc/cdc-wdm0
[01-01_00:00:10:131] Find qmichannel = /dev/cdc-wdm0
[01-01_00:00:10:137] cdc_wdm_fd = 7
[01-01_00:00:11:137] QmiThreadSendQMITimeout pthread_cond_timeout_np=110, errno: 2 (No such file or directory)
[01-01_00:00:12:979] Get clientWDS = 7
[01-01_00:00:13:011] Get clientDMS = 1
[01-01_00:00:13:043] Get clientNAS = 3
[01-01_00:00:13:203] Get clientUIM = 1
[01-01_00:00:13:235] Get clientWDA = 1
[01-01_00:00:13:299] requestBaseBandVersion EC25AUFAR06A01M4G
[01-01_00:00:13:427] requestGetSIMStatus SIMStatus: SIM_READY
[01-01_00:00:13:427] requestSetProfile[1] ctnet///0
[01-01_00:00:13:523] requestGetProfile[1] ctnet///0
[01-01_00:00:13:555] requestRegistrationState2 MCC: 460, MNC: 60, PS: Attached, DataCap: LTE
[01-01_00:00:13:586] requestQueryDataCall IPv4ConnectionStatus: DISCONNECTED
[01-01_00:00:13:683] requestRegistrationState2 MCC: 460, MNC: 60, PS: Attached, DataCap: LTE
[01-01_00:00:13:907] requestSetupDataCall QMUXResult = 0x1, QMUXError = 0xe
Jan 1 00:00:16 buildroot daemon.info : starting pid 755, tty ‘/dev/ttyPS0’: '/sbin/getty -L ttyPS0 0 vt100 ’
Exiting, name server cannot be used: Temporary failure in name resolution (-3) 1 Jan 00:00:16 ntpdate[756]: name server cannot be used: Temporary failure in name resolution (-3)
Welcome to Buildroot
buildroot login: --00000027 0000065a 00001440 00000798 00000027 00000659 00001440 00000798–
MQTTClient_connect is fail…
[01-01_00:00:19:059] requestRegistrationState2 MCC: 460, MNC: 60, PS: Attached, DataCap: LTE
[01-01_00:00:19:251] requestSetupDataCall QMUXResult = 0x1, QMUXError = 0xe
root
Jan 1 00:00:22 buildroot auth.info login[755]: root login on ‘ttyPS0’
[01-01_00:00:24:403] requestRegistrationState2 MCC: 460, MNC: 60, PS: Attached, DataCap: LTE
[01-01_00:00:24:563] requestSetupDataCall QMUXResult = 0x1, QMUXError = 0xe
[01-01_00:00:29:716] requestRegistrationState2 MCC: 460, MNC: 60, PS: Attached, DataCap: LTE
[01-01_00:00:29:876] requestSetupDataCall QMUXResult = 0x1, QMUXError = 0xe
microcom /dev/ttyUSB2
[01-01_00:00:34:931] requestRegistrationState2 MCC: 460, MNC: 60, PS: Attached, DataCap: LTE
[01-01_00:00:35:091] requestSetupDataCall QMUXResult = 0x1, QMUXError = 0xe
AT+QICSGP=1,1,“hctv”,"","",3
[01-01_00:00:40:147] requestRegistrationState2 MCC: 460, MNC: 60, PS: Attached, DataCap: LTE
[01-01_00:00:40:307] requestSetupDataCall QMUXResult = 0x1, QMUXError = 0xe
[01-01_00:00:43:922] requestRegistrationState2 MCC: 0, MNC: 0, PS: Detached, DataCap: UNKNOW
[01-01_00:00:45:362] requestRegistrationState2 MCC: 0, MNC: 0, PS: Detached, DataCap: UNKNOW
AT+CFUN=1
[01-01_00:00:49:876] requestRegistrationState2 MCC: 460, MNC: 1, PS: Detached, DataCap: UNKNOW
[01-01_00:00:49:907] requestRegistrationState2 MCC: 460, MNC: 1, PS: Detached, DataCap: UNKNOW
[01-01_00:00:50:419] requestRegistrationState2 MCC: 460, MNC: 1, PS: Detached, DataCap: UNKNOW
+CPIN: READY
+QUSIM: 1
[01-01_00:00:51:891] requestRegistrationState2 MCC: 460, MNC: 60, PS: Detached, DataCap: UNKNOW
[01-01_00:00:53:556] requestRegistrationState2 MCC: 460, MNC: 60, PS: Attached, DataCap: LTE
[01-01_00:00:53:619] requestRegistrationState2 MCC: 460, MNC: 60, PS: Attached, DataCap: LTE
[01-01_00:00:54:003] requestSetupDataCall QMUXResult = 0x1, QMUXError = 0xe
+QIND: SMS DONE
+QIND: PB DONE
[01-01_00:00:59:061] requestRegistrationState2 MCC: 460, MNC: 60, PS: Attached, DataCap: LTE
[01-01_00:00:59:282] requestSetupDataCall QMUXResult = 0x1, QMUXError = 0xe
[01-01_00:00:59:282] requestSetOperatingMode(1)
[01-01_00:00:59:315] requestSetOperatingMode(0)
+QIND: SMS DONE
[01-01_00:00:59:763] requestRegistrationState2 MCC: 0, MNC: 0, PS: Detached, DataCap: UNKNOW
[01-01_00:01:00:211] requestRegistrationState2 MCC: 460, MNC: 60, PS: Detached, DataCap: UNKNOW
[01-01_00:01:01:588] requestRegistrationState2 MCC: 460, MNC: 60, PS: Attached, DataCap: LTE
[01-01_00:01:01:652] requestRegistrationState2 MCC: 460, MNC: 60, PS: Attached, DataCap: LTE
[01-01_00:01:01:938] requestSetupDataCall QMUXResult = 0x1, QMUXError = 0xe
AT+COPS?
+COPS: 0,0,“460 60 DTM”,7
[01-01_00:01:06:996] requestRegistrationState2 MCC: 460, MNC: 60, PS: Attached, DataCap: LTE
[01-01_00:01:07:156] requestSetupDataCall QMUXResult = 0x1, QMUXError = 0xe
AT+CREG?
+CREG: 0,1
[01-01_00:01:12:212] requestRegistrationState2 MCC: 460, MNC: 60, PS: Attached, DataCap: LTE
[01-01_00:01:12:404] requestSetupDataCall QMUXResult = 0x1, QMUXError = 0xe
AT+CEREG?
+CEREG: 0,1
[01-01_00:01:17:460] requestRegistrationState2 MCC: 460, MNC: 60, PS: Attached, DataCap: LTE
[01-01_00:01:17:620] requestSetupDataCall QMUXResult = 0x1, QMUXError = 0xe
I would appreciate it if you could offer more advice.
