Hello, I’m working with an EC25-AFXD Mini PCIe module plugged into a Mini PCIe to USB adapter board with a Verizon sim card going into a Rasberry Pi. About a month ago this setup was working perfectly and I was able to connect to the internet. More recently, this module no longer shows up as a network interface in Linux. I’ve included the output from ModemManger, NetworkManager, etc. Does anyone have an idea how to solve this? Thanks
ModemManager:
pi@raspberrypi:~ $ mmcli -m 0
General | path: /org/freedesktop/ModemManager1/Modem/0
| device id: bd90018178d349f769cb072a338fdca0f1344972
Hardware | manufacturer: QUALCOMM INCORPORATED
| model: QUECTEL Mobile Broadband Module
| firmware revision: EC25AFXDGAR07A01M1G
| carrier config: hVoLTE-Verizon
| carrier config revision: 05010141
| h/w revision: 10000
| supported: gsm-umts, lte
| current: gsm-umts, lte
| equipment id: 868260050005975
System | device: /sys/devices/platform/soc/20980000.usb/usb1/1-1/1-1.4
| drivers: qmi_wwan, option
| plugin: quectel
| primary port: cdc-wdm0
| ports: cdc-wdm0 (qmi), ttyUSB0 (qcdm), ttyUSB1 (gps),
| ttyUSB2 (at), ttyUSB3 (at), wwan0 (net)
Numbers | own: 6513703670
Status | lock: sim-pin2
| unlock retries: sim-pin (3), sim-pin2 (3), sim-puk (10), sim-puk2 (10)
| state: enabled
| power state: on
| signal quality: 59% (recent)
Modes | supported: allowed: 3g; preferred: none
| allowed: 4g; preferred: none
| allowed: 3g, 4g; preferred: 4g
| allowed: 3g, 4g; preferred: 3g
| current: allowed: 3g, 4g; preferred: 3g
Bands | supported: utran-4, utran-5, utran-2, eutran-2, eutran-4, eutran-5,
| eutran-12, eutran-13, eutran-14, eutran-66, eutran-71
| current: utran-4, utran-5, utran-2, eutran-2, eutran-4, eutran-5,
IP | supported: ipv4, ipv6, ipv4v6
3GPP | imei: 868260050005975
| enabled locks: fixed-dialing
| operator id: 310260
| registration: idle
3GPP EPS | ue mode of operation: csps-2
| initial bearer apn: vzwinternet
| initial bearer ip type: ipv4
SIM | primary sim path: /org/freedesktop/ModemManager1/SIM/0
NetworkManager:
pi@raspberrypi:~ $ nmcli
eth0: connected to Wired connection 1
"TP-Link Ethernet"
ethernet (r8152), 60:A4:B7:59:2F:BA, hw, mtu 1500
ip4 default
inet4 10.10.100.101/22
route4 0.0.0.0/0
route4 10.10.100.0/22
inet6 fe80::76e3:752e:82c1:4e2b/64
route6 fe80::/64
route6 ff00::/8
cdc-wdm0: connecting (prepare) to MPS-EC25
"cdc-wdm0"
gsm (qmi_wwan, option), hw
wlan0: disconnected
"Broadcom BCM43438 combo and Bluetooth Low Energy"
wifi (brcmfmac), 5E:24:FF:B2:37:7A, hw, mtu 1500
ifconfig:
pi@raspberrypi:~ $ ifconfig -a
wwan0: flags=4240<POINTOPOINT,NOARP,MULTICAST> mtu 1500
unspec 00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00 txqueuelen 1000 (UNSPEC)
RX packets 0 bytes 0 (0.0 B)
RX errors 0 dropped 0 overruns 0 frame 0
TX packets 0 bytes 0 (0.0 B)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
/etc/NetworkManager/system-connections/MyModem
[connection]
id=MPS-EC25
type=gsm
autoconnect=true
[ipv4]
method=auto
[gsm]
number=*99#
apn=vzwinternet
[serial]
baud=115200
