I’m using EC25 Mini PCIe.
Which type of GPS antenna can I use? An ACTIVE antenna or a PASSIVE antenna.
Thanks.
Thanks.
Hello tee, thanks for your question
If your requirements for power consumption are not high, we recommend that you use an active antenna. Compared with passive antennas, it can improve sensitivity and reduce signal-to-noise ratio.
