I am using PCIE EC25 module
root@root:/sys# lsusb
Bus 001 Device 006: ID 2c7c:0125 Quectel Wireless Solutions Co., Ltd. EC25 LTE modem
Bus 001 Device 005: ID 04b4:640c Cypress Semiconductor Corp. BCM2045A0
Bus 001 Device 004: ID 04b4:0bdc Cypress Semiconductor Corp. Cypress USB 802.11 Wireless Adapter
Bus 001 Device 003: ID 04b4:bd30 Cypress Semiconductor Corp.
Bus 001 Device 002: ID 0424:2514 Microchip Technology, Inc. (formerly SMSC) USB 2.0 Hub
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
The details are:
/sys# lsusb -t
/: Bus 01.Port 1: Dev 1, Class=root_hub, Driver=ci_hdrc/1p, 480M
|__ Port 1: Dev 2, If 0, Class=Hub, Driver=hub/4p, 480M
|__ Port 1: Dev 3, If 0, Class=Hub, Driver=hub/2p, 480M
|__ Port 2: Dev 5, If 3, Class=Application Specific Interface, Driver=, 480M
|__ Port 2: Dev 5, If 1, Class=Vendor Specific Class, Driver=, 480M
|__ Port 2: Dev 5, If 2, Class=Vendor Specific Class, Driver=, 480M
|__ Port 2: Dev 5, If 0, Class=Vendor Specific Class, Driver=, 480M
|__ Port 1: Dev 4, If 0, Class=Vendor Specific Class, Driver=brcmfmac, 480M
|__ Port 3: Dev 6, If 0, Class=Vendor Specific Class, Driver=option, 480M
|__ Port 3: Dev 6, If 1, Class=Vendor Specific Class, Driver=option, 480M
|__ Port 3: Dev 6, If 2, Class=Vendor Specific Class, Driver=option, 480M
|__ Port 3: Dev 6, If 3, Class=Vendor Specific Class, Driver=option, 480M
|__ Port 3: Dev 6, If 4, Class=Communications, Driver=cdc_ether, 480M
|__ Port 3: Dev 6, If 5, Class=CDC Data, Driver=cdc_ether, 480M
I have these in sys
/sys# find -name '*cdc*'
./bus/usb/drivers/cdc_ether
./bus/usb/drivers/cdc_ncm
./bus/usb/drivers/cdc_wdm
./bus/usb/drivers/cdc_subset
./module/cdc_ncm
./module/cdc_ncm/drivers/usb:cdc_ncm
I have these in dmesg:
[ 14.697151] usb 1-1.3: GSM modem (1-port) converter now attached to ttyUSB0
[ 14.917953] usb 1-1.3: GSM modem (1-port) converter now attached to ttyUSB1
[ 15.167750] usb 1-1.3: GSM modem (1-port) converter now attached to ttyUSB2
[ 15.382967] usb 1-1.3: GSM modem (1-port) converter now attached to ttyUSB3
and these
dmesg | grep cdc
[ 2.614320] usbcore: registered new interface driver cdc_ether
[ 2.632010] usbcore: registered new interface driver cdc_subset
[ 2.651381] usbcore: registered new interface driver cdc_ncm
[ 2.686521] usbcore: registered new interface driver cdc_wdm
[ 15.569717] cdc_ether 1-1.3:1.4 usb0: register 'cdc_ether' at usb-ci_hdrc.1-1.3, CDC Ethernet Device, 06:0c:36:6c:c9:31
[ 28.266284] cdc_ether 1-1.3:1.4 enx060c366cc931: renamed from usb0
I can see the interface as:
enx060c366cc931: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet 192.168.225.48 netmask 255.255.255.0 broadcast 192.168.225.255
inet6 fe80::cd8e:1d10:15f5:f4a8 prefixlen 64 scopeid 0x20<link>
ether 06:0c:36:6c:c9:31 txqueuelen 1000 (Ethernet)
RX packets 60 bytes 3821 (3.7 KiB)
RX errors 0 dropped 0 overruns 0 frame 0
TX packets 70 bytes 5020 (4.9 KiB)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions
BUT I don’t have:
/dev/cdc-wdm0
Not even after I do AT+QCFG=“usbnet”.
AT+QCFG=“usbnet”.
+CIND: 0,3,1,0,0,0,1,0
dev# find -name cd*
root@ken:/dev#
