if i use RILD V3.1.5_master_beta Driver is there a dependency related to the GPS Driver?
currently i use GPS Driver V2.1.9_20190919, if i check manual Quectel_Android_GNSS_Driver_User_Guide_V1.3.pdf it tells me to use:
Added:
gps_cfg.inf → /vendor/etc
if i do a “logcat -s gps_ql -v time” it reports me:
06-22 09:50:08.537 D/gps_ql ( 280): GPS DRIVER VERSION: Quectel_Android_GPS_Driver_V2.1.9-20190919
06-22 09:50:08.538 D/gps_ql ( 280): fail to read /etc/gps_cfg.inf for errno: 2 (No such file or directory)
06-22 09:50:08.538 D/gps_ql ( 280): [rild-nmea] [0]
06-22 09:50:08.538 D/gps_ql ( 280): MODULE_TYPE:
06-22 09:50:08.538 D/gps_ql ( 280): QL_GPS_CHANNEL:rild-nmea
06-22 09:50:08.538 D/gps_ql ( 280): BAUD_RATE:0
06-22 09:50:08.538 D/gps_ql ( 280): init_times = 1, s->init = 1
06-22 09:50:08.543 D/gps_ql ( 280): ql_gps_xtra_init(callbacks=0x7da2a7e140)
06-22 09:50:08.543 D/gps_ql ( 280): ql_agps_init[42]–enter!
06-22 09:50:08.543 D/gps_ql ( 280): ql_agps_init[44]–leave!
06-22 09:50:08.546 D/gps_ql ( 280): ql_loc_ni_init[26]–enter!
06-22 09:50:08.546 D/gps_ql ( 280): ql_loc_ni_init[27]–leave!
06-22 09:50:08.549 D/gps_ql ( 280): ql_loc_agps_ril_init[37]–enter!
06-22 09:50:08.549 D/gps_ql ( 280): ql_loc_agps_ril_init[38]–leave!
06-22 09:50:08.550 D/gps_ql ( 280): ql_agps_set_server[85]–enter!
06-22 09:50:08.550 D/gps_ql ( 280): agps hostname = supl.google.com, port = 7275
06-22 09:50:08.550 D/gps_ql ( 280): ql_agps_set_server[102]–leave!
if i place gps_cfg.inf into /system/etc gps_cfg.inf get´s read and i receive GPS Data on Console using
cat /dev/ttyUSB1 and during logcat -s gps_ql -v time
(gps.default.so is in /vendor/lib64/hw)
but GPS TRACK tool doesn´t get any DATA no Satellite at all !
(even if i enable WiFi or MobileData clear & update AGPS)
Permission is there:
rk3399:/vendor/etc/permissions # ls -la
-rw-r--r-- 1 root root 942 2020-06-21 14:15 android.hardware.location.gps.xml
-rw-r--r-- 1 root root 949 2020-06-22 00:13 android.hardware.location.xml
-rw-r--r-- 1 root root 4825 2020-06-21 14:15 handheld_core_hardware.xml
are this config Parameter still needed using gps / rild-nmea
;MODULE_TYPE=
;NMEA_PORT_PATH=/dev/ttyO1
;BAUD_RATE=9600
and what about these Android Properties related to gps/rild-nmea:
[ro.kernel.android.gps]: [/dev/ttyUSB1]
[ro.kernel.android.gps.max_rate]: [1]
[ro.kernel.android.gps.speed]: [115200]
Kind regards,
Brian
