Good day!
I bought the lte module, I solved a lot of questions using your forum.
There were questions:
Where to get the documentation on how to request a GPS tag from the module.
2.Can the module send SMS that it got in touch?
Is it possible to take information about the signal level lte from the module and transmit it via the Internet channel?
In general, where can I get documentation on the module and is there such information there?
There is a module in the board with the openwrt system
Maybe I wrote the wrong letter I’m sorry for earlier this is my first post, I still have not figured out the topics of how a blind kitten poke.
Hi Alexander,
About your question, please refer to the below detail.
For GPS test, please refer to the below document:
Quectel_EC25&EC21_GNSS_AT_Commands_Manual_V1.1
Yes module support SMS function, Please refer to AT command manual.
Yes. You could use AT command AT+CSQ to get the signal level and send it to the server through TCP or SMS or some other protocols.
You could download some documents from Quectel web site. You also could send email to support@quectel.com to look up help.
Good day!
Thanks for the help, the documentation helped me!
I wanted to ask if you can!
Can i replace IMEI?
How can I fix TTL packets?
I would be very grateful!
Alex,
It is not allowed to replace IMEI as each of device have unique IMEI.
What is meaning of TTL packet? May I know more detail abotu this?
Thank you.
IN ECM Mode the modem is performing NAT. Technically this should be possible to mangle or force all egress TTL to a set value. Does Quectel offer such access to the firewall?
