We are testing VoLTE with an EC25-EUG mini-PCIe module on a private LTE network (band 3, private test PLMN, EPC + IMS core).
Module
- Firmware:
EC25EUGAR06A07M4G_01.001.01.001 - MBN:
Commercial-DT-VOLTE(selected manually, AutoSel = 0) AT+QCFG="ims",1- PDP contexts: CID1
internet, CID2ims(IPV4V6)
What works
- The module attaches; the Attach Accept advertises “IMS voice over PS session in S1 mode: Supported”.
- After
AT+CFUN=0/1, the module opens the IMS PDN by itself (CID2, QCI 5).AT+CGCONTRDP=2returns the IP and the P-CSCF address from the PCO. AT+QPINGto the P-CSCF over the IMS PDN succeeds (3/3, ~57 ms).
The problem
- The module never sends a SIP REGISTER. A capture on the S1-U side shows no SIP traffic at all over 8 minutes; only our ICMP pings.
AT+QCFG="ims"stays at1,0(not registered).- With
ROW_Generic_3GPP, the IMS PDN is not even opened.
We suspect the DT MBN only enables the IMS client on Deutsche Telekom PLMNs.
Questions
- Could you share the latest firmware for this module (
EC25EUGAR06A11M4Gor newer)? - Is there a generic or open-market VoLTE MBN, or an MBN template, that does not restrict IMS to a given operator’s PLMN, for a private network like ours?
- Otherwise, which settings (NV items or AT commands) need to change so that the IMS client registers on a PLMN that is not in the MBN?
Thank you in advance.
