is there any way to confirm that EC25 modem restarts are caused by power issues (limited USB power)? Is there any way to collect/save debug messages?
Thank you in advance,
J.
J.
If the module or terminal is restarted due to USB power supply, the debug log will also be interrupted, and you may not be able to analyze it through the debug log. I recommend that you cross-validate with VBAT
What is the EC25 maximum power consumption? Based on the documentation 3.8V (nominal) * 1.8A (max VBAT_RF) + 3.8V * 0.8A (max VBAT_BB), which sums up to roughly 10W. Is that correct?
Would you be able to respond to the message below?
