I have resent the sharing link. Maybe please check your spam folder.
Hello! Could you send the latest firmware for EC25-EUC to me?
Please check your current firmware version. Much appreciation
Can I get the newest stable firmware version for EC25ECGAR06A04M1G_01.004.01.004 (in Teltonika RUT240)
Thanks!
I have sent the latest firmware to your email too,pls check
I would like to update my EC25‑EUX modules. Could you please share the latest firmware?
I am currently on EC25EUXGAR08A07M1G.
Thank you very much for your help.
I would need the latest firmware for the Quectel EC25-EUX (and flashing tool) as I’m experiencing stability issues.
I currently have firmware version EC25EUXGAR08A13M1G.
Thank you in advance for help.
Hello please send EC25-EC latest firmware to me
my email kitiwan.nbtc@gmail.com]
Current version =EC25ECGAR06A15M1G
thanks.
Could I please get the latest firmware for EC25-EUX?
Myurrent version is EC25EUXGAR08A14M1G.
Reason is that I have problems connecting to 4G network.
My email address is sdreyer()gmx.de (please substitute () with @ sign).
Many thanks!
Myurrent version is EC25EUXGAR08A19M1G
my mail acmeaka@gmail.com
I urgently need the old firmware version EC25EUXGAR08A03M1G.
Newer versions do not work with my device, and the device manufacturer only supports this specific version.
The original module failed, and the replacement module came with a newer firmware. I need to downgrade it to EC25EUXGAR08A03M1G.
Could you please send me the EC25EUXGAR08A03M1G firmware, QFlash tool, and Windows USB drivers?
Mail: eltmaa (at) gmail.com
Thank you!
Hello Quectel Support,
I am requesting the latest available firmware for my EC25-EUX modules.
Current firmware version (from AT+QGMR):
EC25EUXGAR08A19M1G_A0.302.A0.302
Reason for request (critical bug):
I’ve identified a firmware-level deadlock in A0.302.x: when AT+CMGL=4 is issued on SR (Status Report) memory while the modem is processing +CDSI: URCs (even ~2s after), the AT parser deadlocks waiting on an internal mutex. Result: modem becomes completely unresponsive; only physical power cycle recovers it. AT+CMGR=N is my current workaround. If a firmware update addresses SR memory concurrency, SMS stack stability, or AT+CMGL timeout issues, I urgently need it.
Request details:
- Latest stable firmware package for EC25-EUX
- Corresponding flashing tool:
- Required USB/serial drivers for the flashing process
- Instructions on how to back-up the current firmware
Important constraint:
My modems are deployed in a pool configuration where I only have access to ONE serial port (UART1) per modem, the 16 modem pool is connected via USB. (Bought from yxinternet[.]com)
Can firmware flashing be performed via a single UART/serial connection?
Contact email for firmware delivery: alltrix_mail@proton.me
Thank you for your support.
Hello!
I would like to request the firmware for the Quectel EC25-E.
I need version EC25EFAR06A11M4G
Our current modules firmware is: EC25EFAR06A06M4G.
Thank you in advance!
Thank you very much.
Dear Quectel Support Team,
I am currently using a Quectel EC25-EUX LTE module integrated in a USB dongle.
The module reports the following information via the ATI command:
Model: EC25EUX
Revision: EC25EUXGAR08A07M1G
I would like to kindly request:
The official firmware package (.pac or equivalent) for this exact revision (EC25EUXGAR08A07M1G), so that I can keep a backup of the original firmware before performing any upgrades.
The latest recommended firmware for the EC25-EUX series (GAR08AxxM1G branch), including any release notes or documentation you can provide (changelog, known issues, etc.).
The latest official version of your firmware upgrade tool for Windows (QFlash / Quectel Software Upgrade Tool), compatible with the EC25-EUX, along with any relevant usage guide.
The module is currently used for development, testing and evaluation purposes (non‑production).
If you require any additional information (IMEI, serial number, region, operator), I will be happy to provide it.
Best regards,
I haven’t received a response, so I’m bringing this up again.
Best regards,
Could you please provide the latest firmware package and flashing tool for my EC25-EUX module?
Module details:
Model: Quectel EC25-EUX. (inside BLIIOT ARMxy)
Current firmware: EC25EUXGAR08A13M1G_20.200.20.200
ATI revision: EC25EUXGAR08A13M1G
Use case: VoLTE / IMS testing on Linux with Asterisk
Operator: Free Caraibe, PLMN 34004
SIM IMSI prefix: 34009
I am looking for the latest compatible EC25-EUX firmware, ideally EC25EUXGAR08A19M1G_A0.304.A0.304 or the newest recommended version, plus the correct QFlash/QFirehose upgrade tool and instructions.
Thank you.
Can you please assist with the firmware for EC25-EUXGR-128-SGNS?
It’s stuck in RNDIS mode and I can’t give back the firmware version.
I can get it in QDL and hopefully with the firmware revert the ECM/RNDIS state that does not expose the serial ports.
Thank you!
Dear Customer,
I have sent the latest firmware through email. Please check there.
