Hi,@akalinismet
I have sent them to your email,pls check
Thank you very much ![]()
EC25EUXGAR07A08M1G I’m looking for this firmware, is it possible to have it? Thanks a lot to whoever helps me
Hi,@BHMod
Sorry,According to the firmware version you need, I haven’t found any firmware related to the R07 baseline.
Hi, thank you very much for your reply, I will explain in detail what happened and what I did, I have this EC25-EUXGR I installed the drivers and it worked very well with the Italian sim, then, I did the firmware update EC25EUXGAR08A09M1G_20.003. 20.003 and now it no longer picks up the network, it no longer picks up any signal, then, I made various attempts to then try to install the EC25-EU version, which obviously failed and now it is no longer even recognized by the PC, the blue LED lights up very weak and batsa. Could you help me? thank you very much indeed.
Hi,@BHMod
Did you upgrade from the R07 baseline to the R08 baseline? There is a high risk in cross-baseline upgrades for the module, which may cause the module to stop working. It is recommended that you contact the after-sales service for handling.
I tried to put this EC25EUGAR08A01M4G_01.001.01.001
hello can you send me lastest firmware link and update tool windows or linux
ATI
EC25
Revision: EC25EUXGAR08A08M1G
Hi, I have firmware EC25EUXGAR08A19M1G_A0.200.A0.200.
Is there an update available?
Hi,@BHMod
What’s the initial firmware version of your module? You can provide the IMEI number, and I can help you query it.Then I’ll send you the latest stable firmware version, and you can try it again.
Hi,@Javier_Ponc
I have sent to you via email,pls check.
Hi,@hermesthecat
I have sent to you via private message,pls check.
Thanks, I will try to load the firmware.
Здравствуйте, пришлите пожалуйста, прошивку для ec25euxgar08a05m1g —> ec25euxgar08a07m1g
и если не затруднит последнюю версию на электронную почту wawan2005rtf@mail.ru
Hi,@Wawan2005
Hello, i have EC25-EUX modules. Please send me firmware. voitkevich.a@gmail.com
Hi,@voitkevich.a
Could you tell me your current firmware version?You can use the “ATI” command to check it.Thanks.
Could you please send me latest firmware for these modules?
Current version is
EG21GGBR07A11M1G
EC21EFAR06A05M4G
EC25EFAR08A06M4G
EC25EFAR06A17M4G
Thank you.
Hi,@jh11111
Thanks for the file.
Could you please check if this is the latest version of EG25-G?
EG25GGBR07A08M2G_30.204.30.204
