EC25-E is not detected
I am getting the following error while connecting the EC25-E module
Unknown USB Device (Device Descriptor Request Failed)
This device was working OK and device drivers are properly installed. (Windows 10 OS)
hi,ketan.asm:
I recommend you download the driver file from the link below and reinstall it. If the problem persists, you can test it on another computer.
https://quectel123-my.sharepoint.cn/:u:/g/personal/ae-fae_dom_quectel_com_cn/EcZO_Nnq_8JIghLpvVGu04UB4wKWDseVmW9XmsEHvDPN6g?e=5geW3p
HAI, We also facing similar issue. we installed this driver ,its installed and detected but not working with ISP. The driver automatically enable and disable .and was connected once a few seconds then its not connected .
thank you
please try it again!
Quectel_LTE&5G_Windows_USB_Driver_V2.2.4.zip
hai , still same issue.hardware detected and disabled on device manager.
can i get EC25E driver?and firmware? so i will start the steps from beginning
NOW I INSTALLED ANOTHER NEW MODEM ITS SHOWING THIS REVISION. Shall i upgrade firmware?EC25EFAR02A08M4G
Yes, you can upgrade the firmware version, but I personally think the driver has nothing to do with the firmware version
Dear, is this the latest firmware for this module(EC25EFAR02A08M4G)? shall i upgrade ?
and also on that folder i upgraded the below files only.
is that correct? or should i upload&upgrade this FIREHOSE containing files aswell?
thank you
