I am trying to update my EC25-E mPCIe modem (revision EC25EFAR02A06M4G) with newer firmware in Windows 7. QFlash v4.15, firmware is from EC25EFAR06A07M4G_01.007.01.007.zip container. Driver version is V2.1.
First, I run QFlash app, then select COMxxx (which is DM port in Device Manager), then select 460800 baudrate, then select prog_nand_firehose_9x07.mbn file and finaly click Start.
QFlash app opens the port, then “send edl mode cmd (Portxxx)” and stuck on “Detect dynamic com port xxx…”. After a few minutes I get “FAIL, Confirm dynamic com port xxx timeout(N)!” message.
What do I do wrong? Could you please recommend the right approach.
the password is good, thanks. The problem is still the same. I chose DM AT port and clicked Start. After a minute or so it hangs on “Detect dynamic com port146…".
Is it possible that the problem is with FW? Could you please send the latest FW for EC25-E mPCIe module?
Dear Sir,
Could you share more information with us about your issue? Normally, if you want to upgrade the firmware, you just need unzip the firmware package, and choose any file inside the package, then just click start button in Qflash. It will upgrade the firmware automatically. Thanks!
I bought a WE826-T2 wi-fi router but I just see an x at the signal strength. It detects the simcard but shows 0 signal. I wonder if theres something wrong with it. can i get a link to firmware upgrade? all that I get on the internet keep saying its an incorrect model.
Please help
Dear Boazvida,
If you want to upgrade the module firmware, it is better to check the current firmware version with ATI command, then we can help to provide the right firmware package. And you can email to support@quectl.com to get it. Thanks!
I am trying to update my em12g modem (version EM12GPAR01A07M4G_MSFT) with newer firmware in Windows 10. QFlash version 4.18, the firmware is taken from EM12GPAR01A21M4G_01.007.01.007.zip the container. The driver version is V2.1.
First, I launch the QFlash application, then select COMxxx (which is the DM port in device manager), then select the data transfer rate of 9600, then select the prog_nand_firehose_9x07.mbn file, and finally click Start.
The QFlash application opens the port, then “sends the edl mode cmd (Portxxx) command” and freezes on “Detecting dynamic com port xxx…”. After a few minutes, I get the message “ERROR, confirm the timeout of dynamic com port xxx(N)!".
