Hello
I am using a GSM voice gateway containing 8 Quectel EC25-E modules. I need to use the USB Audio Class (UAC) interface to transfer GSM call audio between the EC25-E and a Windows PC, including both microphone input and speaker/output audio.
Module information:
EC25-E
Revision: EC25EFAR08A06M4G
Firmware: EC25EFAR08A06M4G_20.201.20.201
USB VID/PID: 2C7C:0125
Current USB configuration:
AT+QCFG=“usbcfg”
+QCFG: “usbcfg”,0x2C7C,0x0125,1,1,1,1,1,0,1
UAC activation:
AT+QPCMV=1,2
AT+QPCMV?
+QPCMV: 1,2
The GSM voice call itself works correctly with ATD/ATA/ATH and the call is successfully established.
However, there is NO audio in either direction. I cannot hear the remote party and I cannot send microphone audio.
There is also no physical audio connector, speaker or microphone on my gateway. Therefore, I need the call audio to be transferred through USB UAC to the Windows PC.
The main problem is that Windows does not detect any USB Audio/UAC device from the EC25-E. Nothing appears under:
- Sound, video and game controllers
- Audio inputs and outputs
Only the USB serial interfaces are detected, for example:
USB Serial Device (COM6)
I also explicitly reapplied the USB configuration:
AT+QCFG=“USBCFG”,0x2C7C,0x0125,1,1,1,1,1,0,1
AT+QPCMV=1,2
AT+QPCMV?
+QPCMV: 1,2
Even during an active voice call, no USB Audio device appears in Windows and there is no usable audio path.
After reboot, QPCMV returns to:
+QPCMV: 0,0
which I understand may be normal because QPCMV=1,2 must be enabled again after boot.
Could you please confirm whether firmware EC25EFAR08A06M4G_20.201.20.201 has any known USB UAC/audio limitation or bug?
If possible, please provide the latest recommended firmware for EC25-E EFAR that fully supports USB Audio/UAC for voice calls, together with the appropriate flashing tool and instructions.
Please confirm that the firmware is compatible with:
EC25-E / EC25EFAR08A06M4G
VID: 2C7C
PID: 0125
I have 8 identical EC25-E modules in the gateway, so I would like to test the firmware on one module first and then update the other 7 if the UAC/audio issue is resolved.
Thank you for your support.
