Hello Quectel,
I’m using the EC25-E (Mini PCIe series) with Firmware: EC25EFAR06A11M4G
I need last FIRMWARE and drivers for Windows 10 64bits.
Regards,
RSilva
Hello Quectel,
Regards,
RSilva
Thanks,
Can you also send me the correct QFLASH?
I have sent it to your email,pls try
Thanks,
I tested it and everything worked.
How can I play a wave file during a call?
Can you help me?
Please refer to the relevant AT Command in Chapter 12
Quectel_EC2x&EG9x&EG2x-G&EM05_Series_AT_Commands_Manual_V2.0.pdf (1.7 MB)
Can you send me file with driver & firmware for EC25 ?
I have -E version.
Please provide your current specific version
AT+QGMR
Unfortunately, the modem on my Dell E6430 laptop is not detectable in the WWAN connector. Do you know what is causing this?
pls update driver,and I have sent it to your email
There is no way to update the driver, because the device is not visible even in the Device Manager
What about trying to replace another PC?
Yes, I try in Dell E6400 is the same effect. I installed DW5570 in E6430 and E6400 in WWAN port and works great.
If you are our enterprise user, I suggest that you solve this problem through Ticket
We are not enterprise user. We actively use your company’s products. If not through “Ticket”, I understand that there is no other solution?
It is not possible to infer the specific reason at this time. It may be due to the compatibility of the driver with the current DELL system
