I have limited information available from AT manual regarding supported bands and their bit flags, as follows…
Band 1 = 0x1
Band 2 = 0x4
Band 5 = 0x10
Band 8 = 0x80
Band 40 = 0x8000000000
Band 41 = 0x10000000000
I request to provide full information, like all supported bands and their respective bit flags
Regards
snowgum
December 28, 2022, 7:54am
2
ketan.asm:
Band 2 = 0x4
That one is incorrect. B2 is 0x2
The algorithm is simple. The bit corresponding to the band number is set, and that binary value is converted to hexadecimal.
So B1 had bit 1 set. Binary 1 is 0x1.
B5 has bit 5 set. Binary 10000 is 0x10, and so on.
B1 1
B3 4
B5 10
B7 40
B8 80
B20 80000
B28 8000000
B38 2000000000
B40 8000000000
B41 10000000000
There’s a Linux shell script to list the values here: https://pastebin.com/qbbkvyEc
Thanks a lot.
Now only thing that needs to be figured out is the supported LTE bands in EC-25E
snowgum
December 29, 2022, 6:38am
4
Post the output from AT+QCFG="band" and I’ll decode it for you.
That’s with the default band mask in place, of course. If you’ve modified that in the past, you’re supposed to be able to restore the default mask with: AT+QCFG="band",FFFF,7FFFFFFFFFFFFFFF
Hi, snowgum,
Thank you very much for the information; the issue has been resolved.
I am really sorry for the late reply.
Regards
