EC25-E and EG25-G FTPS Explicit server Login
Hallo, i use multiple EC25-E and EG25-G in our embedded devices. Until now we use FTP to down and upload our data.
Now we are forced from our IT department to use FTPS. Both (EC25-E and EG25-G) devices offer selection of Explicit FTPS connection in - EC2x&EG2x&EG9x&EM05_Series_FTP(S)_Application_Note.pdf:
AT+QFTPCFG=“ssltype”,0" 0 FTP client
AT+QFTPCFG=“ssltype”,1" 1 FTPS implicit encryption
AT+QFTPCFG=“ssltype”,2" 2 FTPS explicit encryption
setting ssltype = 2 does not
There is only a implicit FTPS example provided.
  1. Does the EC25-E and EG25-G support explicit FTPS?
  2. Following the example, with setting ssltype = 2, NO explicit FTPS connection can be established,
  3. How to change the implicit FTPS example to make it work for explicit FTPS?
  4. Is there a explicit FTPS example available?
  5. How does the Certificate Exchange work with explicit FTPS
informations about this topic would be highly appreciated.
regards,
feuerwolf
SOLVED this Issue unsing diferent ports
Thank you for your inquiry
