Hi All,
I have purchased EC25 development kit.
And connected to Ubuntu 14 host ,but device is not getting using via adb devices command.
created file adb_usb.ini in .android directory and wrote usb vid 0x2c7c .
what might be the reason.
Regards
Richu
what does “lsusb” tells you?
Did you added the Vendor specific Changes to Kernel as described in Driver manual?
Regards,
Brian
lsusb
Bus 006 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 005 Device 002: ID 046d:c077 Logitech, Inc. M105 Optical Mouse
Bus 005 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 006: ID 0403:6001 Future Technology Devices International, Ltd FT232 Serial (UART) IC
Bus 001 Device 007: ID 2c7c:0125
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
can you share the driver manual?
Hi
Which kernel version are you using?
pls use the command “uname -a” to check.
Hi ,
kernel version is 4.4.0-138-generic
Please refer to the attachment and try using 4.4.1
Hi, Puck
I have same problem with richucjaply.
Your link is broken.
Please share again new link
Quectel_Linux_USB_Serial_Option_Driver_V1.0.zip
HI Puck,
I have a important question, pls help.
With new module EC25E(EC25EFAR06A11M4G) that bought from quectel.
Can I use ADB shell or not ?
But i encountered a issues that when i received a EVB from local FEA , I can use ADB shell, but after i have a new module and soldered on PCB, i see that, i can’t use ADB shell any more.
Are there any errors here or must use QuecOpen to open ADB shell
thank you
