[EC25] /dev/cdc-wdm0 is not created
Dear support,
I’m trying to port QMI_WWAN driver to my android device with EC25-J module.
Driver version: Quectel_Linux&Android_QMI_WWAN_Driver_V1.2.1
The AT commands is working. I can saw device is attached to LTE.
at+creg=2
at+creg?
+CREG: 2,1,“3585”,“4CB0A21”,7
at+cops?
+COPS: 0,0,“Chunghwa Telecom”,7
According to document Quectel_LTE5G_Linux_USB_Driver_User_Guide_V2.0.pdf
There should be a device /dev/cdc-wdm0 be created but I can’t see it. Am I missing something?
Android 12 Kernel 5.4.191
USB ports
STZDR20:/ # lsusb
Bus 003 Device 001: ID 1d6b:0003
Bus 002 Device 002: ID 2c7c:0125 //EC25
Bus 001 Device 001: ID 1d6b:0002
Bus 002 Device 001: ID 1d6b:0002
/dev
STZDR20:/ # ls /dev/cdc*
ls: /dev/cdc*: No such file or directory
ifconfig -a
STZDR20:/ # ifconfig -a
wwan0 Link encap:Ethernet HWaddr 72:78:48:32:d5:01 Driver qmi_wwan_q
NOARP MTU:1500 Metric:1
RX packets:0 errors:0 dropped:0 overruns:0 frame:0
TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:0 TX bytes:0
dmesg:
[ 3.397548] usbcore: registered new interface driver cdc_wdm
[ 18.404567] qmi_wwan_q 2-1:1.4: cdc-wdm0: USB WDM device
[ 18.408956] init: Created socket ‘/dev/socket/ipacm_log_file’, mode 660, user 1001, group 1001
[ 18.428294] qmi_wwan_q 2-1:1.4: Quectel Android work on RawIP mode
[ 18.448126] init: starting service ‘vendor.mutualex’…
[ 18.512509] qmi_wwan_q 2-1:1.4: rx_urb_size = 1520
[ 18.512982] init: starting service ‘vendor.port-bridge’…
[ 18.527167] qmi_wwan_q 2-1:1.4 wwan0: register ‘qmi_wwan_q’ at usb-xhci-hcd.2.auto-1, WWAN/QMI device, aa:e6:28:b0:29:cd
[ 18.542794] init: starting service ‘vendor.ril-daemon’…
[ 18.550608] coresight-remote-etm soc:modem_etm0: Connection established between QMI handle and 2 service
Thanks~
diff --git a/system/core/init/devices.cpp b/system/core/init/devices.cpp
old mode 100644
new mode 100755
index ada1e28..9386601
--- a/system/core/init/devices.cpp
+++ b/system/core/init/devices.cpp
@@ -407,6 +407,8 @@ void DeviceHandler::HandleDeviceEvent(const Uevent& uevent) {
             int device_id = uevent.minor % 128 + 1;
             devpath = StringPrintf("/dev/bus/usb/%03d/%03d", bus_id, device_id);
+    } else if (uevent.subsystem == "usbmisc" && !uevent.device_name.empty()) {
+        devpath = "/dev/" + uevent.device_name;
     } else if (StartsWith(uevent.subsystem, "usb")) {
         // ignore other USB events
         return;
Please apply the patch.
Hi Bean,
It’s worked!
Many thanks!
My device “Arcadyan AW1000”,RG500QEAAAR13A01M4G_01.200.01.200
The same situation “/dev/cdc*: No such file or directory”,
I don’t know much about Linux systems. How do I find “devices.cpp”? Please help me. Thank you.
Is it Android?
What is the Android?
Please show
cat /sys/kernel/debug/usb/devices
It is 5g cpe,Flash the latest Openwrt system
I found the file, but didn’t write anything
Please check whether is is recognized in USB or PCIe.
Tue Dec 31 07:10:30 2024 : usb-modeswitch Go 1-1
Tue Dec 31 07:10:30 2024 : usb-modeswitch Found USB Storage
Modem Logging
Quectel module do not need the usb-modeswitch.
I found the information, thank you.
Use the following command to set up,the modem to apply changes - power toggle it.
AT+QCFG=usbnet # check the current mode
AT+QCFG=usbnet,0 # set QMI or RMNET
AT+QCFG=usbnet,1 # set ECM
AT+QCFG=usbnet,2 # set MBIM
Yes.
Only in RMNET/MBIM mode we can see the /dev/cdc-wdm0.
We ran into the same problem on Android 16 and found that the following ueventd config works as an alternative to patching the devices.cpp:
subsystem usbmisc
  devname uevent_devpath
  dirname /dev
@antweb
Great!
In some cases it is not allowed to modify the devices.cpp.
