Hi ,
I am using EC25 and EG25 LTE module
I want to connect to Azure MQTT broker
In the existing implementation device successfully able to perform the DPS ( device provisioning service ) and after that got the following information
- IoT hostname = ABC-IoT-Hub-XYZ.azure-devices.net
- Device ID = 10009003
- Also SAS (SharedAccessSignature ) is also available / can be generated by the device
With above info , How to connect to the Azure MQTT broker ?
Using AT+QMTOPEN command I can supply the IoT hostname but where to supply the device ID and SAS information ?
any working log or sample AT command with explanation will help
