Hello MARcvE, thanks for your question
The AT+QPCMD command is applicable to Quectel’s GSM series products. On EC25, you can use the AT+QPCMV command to enable this function.
If you want to set the URC report of the incoming call number when ringing, you need to execute the AT+QURCCFG=“urcport”,“uart1” command to report through the serial port, and then execute AT^DSCI=1 (not save when power off) to enable the phone status report, thank you.
