power cycling, reseating SIM (which works in 2nd EC25-AFX device and phone without issue) and no matter what when I do “AT+COPS=?” it always comes back with: +CME ERROR: 3
Even “AT+CLAC” comes back with an error. So I don’t know what to try. Can anyone help out with some suggestions please? Thanks in advance!
Yes this is what I get when I do the AT and ATI commands:
AT
ATI
EC25
Revision: EC25AFXGAR07A04M1G
Yes I read that also about the “Operation not allowed” however it doesn’t make sense to me because I am unaware of any restrictions or even how that would be restricted. Which is why I tried the “AT&F” in hopes that if there was a restriction for some reason it would be gone with the factory defaults loaded.
Please let me know anything else I can attempt, thank you.
How could I check that? I have another EC25-AFX that’s working fine. Would there be something I can do to compare that to this and then save it if that’s what it needs?
Since the SIM works in everything else.. Is there anything else I can try? Is there any diagnostic I can run? For some reason I think I may have a bad solder but, not sure.
