Hello, I am running an EC25-AF on USB/UAC and I cannot change the Sample rate to 16 khz. Only 8khz available.
Sound quality is unacceptable (extremely low volume and robotic inbound or even outbound is forcing 8khz).
It appears the issue may be software-related but the firmware you are using is the latest one.
As a start can you try to set this configuration using AT command where you can set the echo,noise suppressor and digital gain to improve the sound quality, AT+QAUDMOD :
Please try this command and let us know the outcome.
I have a few add on question from my side:
a) The sound quality is coming from Speaker or headset.
b) Did you have a chance to try on another similar EC25 module.
@Alvin295337. Hello,
Thanks, but I want to clarify that this is NOT an echo, noise, or gain issue. AT+QAUDMOD will not solve the problem.
The issue is specifically that the USB Audio Class (UAC) interface is hardcoded to 8kHz sample rate in the firmware. Here is the evidence:
AT+QDAI? returns: 1,0,0,5,0,1,1,1 = Confirming the PCM interface is configured for 16kHz
When using AT+QPCMV=1,2 (UAC mode), the USB audio device exposes only 8kHz to the host OS.
Confirmed in your documentation (?) “EC2x&EG9x Voice Over USB and UAC Application Note” explicitly states that PCM data over USB is fixed at 8kHz sampling rate, 16-bit linear, little-endian.
My questions are:
Is there a firmware update or AT command that can change the USB UAC output to 16kHz when an AMR-WB call is active?
If not, which Quectel module supports wideband audio (16kHz) over the USB/UAC interface on a North America network?
Currently your using the latest firmware, i will try to check internally for any update of the next firmware release.
At the moment there is no module on output of 16kHz mostly fixed at 8kHz.Probaly we can have a patch in new firmware.
One more thig, can i know are you testing using our evb kit? and what is the codec used?:
if you use ALC5616 realtech it can work when you set AT+QDAI command.
