Below is my example, please refer to it.
root@ubuntu:/mnt/hgfs# mmcli -m 0 -e
successfully enabled the modem
General | dbus path: /org/freedesktop/ModemManager1/Modem/0
| device id: 9cb14927bc4ca3e9548c978fa3fef4950ef44aa6
Hardware | manufacturer: QUALCOMM INCORPORATED
| model: QUECTEL Mobile Broadband Module
| revision: EC25EFAR06A08M4G
| h/w revision: 10000
| supported: gsm-umts, lte
| current: gsm-umts, lte
| equipment id: 864430010001091
System | device: /sys/devices/pci0000:00/0000:00:11.0/0000:02:03.0/usb1/1-1
| drivers: qmi_wwan, option1
| plugin: Quectel
| primary port: cdc-wdm0
| ports: cdc-wdm0 (qmi), ttyUSB0 (qcdm), wws35u1i4 (net),
| ttyUSB2 (at), ttyUSB3 (at)
Status | lock: sim-pin2
| unlock retries: sim-pin (3), sim-puk (10), sim-pin2 (3), sim-puk2 (10)
| state: registered
| power state: on
| access tech: lte
| signal quality: 42% (recent)
Modes | supported: allowed: 2g; preferred: none
| allowed: 3g; preferred: none
| allowed: 4g; preferred: none
| allowed: 2g, 3g; preferred: 3g
| allowed: 2g, 3g; preferred: 2g
| allowed: 2g, 4g; preferred: 4g
| allowed: 2g, 4g; preferred: 2g
| allowed: 3g, 4g; preferred: 3g
| allowed: 3g, 4g; preferred: 4g
| allowed: 2g, 3g, 4g; preferred: 4g
| allowed: 2g, 3g, 4g; preferred: 3g
| allowed: 2g, 3g, 4g; preferred: 2g
| current: allowed: 2g, 3g, 4g; preferred: 4g
Bands | supported: egsm, dcs, utran-1, utran-5, utran-8, eutran-1, eutran-3,
| eutran-5, eutran-7, eutran-8, eutran-20, eutran-38, eutran-40,
| eutran-41
| current: egsm, dcs, utran-1, utran-5, utran-8, eutran-1, eutran-3,
| eutran-41
IP | supported: ipv4, ipv6, ipv4v6
3GPP | imei: 864430010001091
| operator id: 46000
| operator name: CMCC
| registration: home
3GPP EPS | ue mode of operation: csps-2
SIM | dbus path: /org/freedesktop/ModemManager1/SIM/0
root@ubuntu:/mnt/hgfs# mmcli -b 0
error: couldn’t find bearer at ‘/org/freedesktop/ModemManager1/Bearer/0’: ‘not found in any modem’
root@ubuntu:/mnt/hgfs# cd …
root@ubuntu:/mnt# cd …
root@ubuntu:/# mmcli -m 0 --simple-connect=“apn=cmnet”
successfully connected the modem
root@ubuntu:/# ifconfig
ens33: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet 192.168.190.139 netmask 255.255.255.0 broadcast 192.168.190.255
inet6 fe80::d:db43:10e6:a440 prefixlen 64 scopeid 0x20
ether 00:0c:29:7d:b0:f9 txqueuelen 1000 (Ethernet)
RX packets 1200 bytes 1279260 (1.2 MB)
RX errors 0 dropped 0 overruns 0 frame 0
TX packets 636 bytes 69610 (69.6 KB)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
lo: flags=73<UP,LOOPBACK,RUNNING> mtu 65536
inet 127.0.0.1 netmask 255.0.0.0
inet6 ::1 prefixlen 128 scopeid 0x10
loop txqueuelen 1000 (Local Loopback)
RX packets 288 bytes 24626 (24.6 KB)
TX packets 288 bytes 24626 (24.6 KB)
root@ubuntu:/# mmcli -b 0
General | dbus path: /org/freedesktop/ModemManager1/Bearer/0
| type: default
Status | connected: yes
| suspended: no
| interface: wws35u1i4
| ip timeout: 20
Properties | apn: cmnet
| roaming: allowed
IPv4 configuration | method: static
| address: 10.241.136.45
| prefix: 30
| gateway: 10.241.136.46
| dns: 211.138.180.2, 211.138.180.3
| mtu: 1500
Statistics | duration: 329
root@ubuntu:/# ifconfig -a
RX packets 1251 bytes 1285033 (1.2 MB)
TX packets 695 bytes 74898 (74.8 KB)
RX packets 321 bytes 27423 (27.4 KB)
TX packets 321 bytes 27423 (27.4 KB)
wws35u1i4: flags=4240<POINTOPOINT,NOARP,MULTICAST> mtu 1500
unspec 00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00 txqueuelen 1000 (UNSPEC)
RX packets 0 bytes 0 (0.0 B)
TX packets 0 bytes 0 (0.0 B)
root@ubuntu:/# ifconfig wws35u1i4 10.241.136.45
RX packets 1253 bytes 1285300 (1.2 MB)
TX packets 697 bytes 75072 (75.0 KB)
RX packets 333 bytes 28395 (28.3 KB)
TX packets 333 bytes 28395 (28.3 KB)
wws35u1i4: flags=4305<UP,POINTOPOINT,RUNNING,NOARP,MULTICAST> mtu 1500
inet 10.241.136.45 netmask 255.255.255.255 destination 10.241.136.45
inet6 fe80::b1a1:6bc:c482:2668 prefixlen 64 scopeid 0x20
TX packets 1 bytes 48 (48.0 B)
root@ubuntu:/# ping -I wws35u1i4 www.baidu.com
PING www.a.shifen.com (14.215.177.38) from 10.241.136.45 wws35u1i4: 56(84) bytes of data.
64 bytes from 14.215.177.38 (14.215.177.38): icmp_seq=1 ttl=49 time=255 ms
64 bytes from 14.215.177.38 (14.215.177.38): icmp_seq=2 ttl=49 time=68.8 ms
64 bytes from 14.215.177.38 (14.215.177.38): icmp_seq=3 ttl=49 time=84.8 ms
64 bytes from 14.215.177.38 (14.215.177.38): icmp_seq=4 ttl=49 time=64.7 ms
64 bytes from 14.215.177.38 (14.215.177.38): icmp_seq=5 ttl=49 time=80.7 ms
64 bytes from 14.215.177.38 (14.215.177.38): icmp_seq=6 ttl=49 time=106 ms
64 bytes from 14.215.177.38 (14.215.177.38): icmp_seq=7 ttl=49 time=77.2 ms
