EC25-A Firmware needed
AT+CVERSION
VERSION: EC25AFAR05A04M4G
Aug 18 2017 17:10:17
Authors: QCT
Looking for a newer version that’ll hopefully allow me to register on ATT network as this version currently won’t register.
The latest firmware version has been sent to you by email, please test it again
Hi - Can I also get a copy of this firmware:
at+cversion
VERSION: EC25AFAR05A07M4G
Oct 27 2020 19:43:11
Authors: QCT
Hi - After the new firmware, I can no longer connect for some reason. No registration state. Is there any suggestions?
I am also trying to connect to AT&T network.
[11-14_14:43:34:230] QConnectManager_Linux_V1.6.1
[11-14_14:43:34:232] Find /sys/bus/usb/devices/1-1.3 idVendor=0x2c7c idProduct=0x125, bus=0x001, dev=0x006
[11-14_14:43:34:233] Auto find qmichannel = /dev/cdc-wdm0
[11-14_14:43:34:233] Auto find usbnet_adapter = wwan0
[11-14_14:43:34:233] netcard driver = qmi_wwan_q, driver version = V1.2.1
[11-14_14:43:34:234] Modem works in QMI mode
[11-14_14:43:34:259] cdc_wdm_fd = 7
[11-14_14:43:34:359] Get clientWDS = 17
[11-14_14:43:34:392] Get clientDMS = 1
[11-14_14:43:34:424] Get clientNAS = 3
[11-14_14:43:34:458] Get clientUIM = 2
[11-14_14:43:34:491] Get clientWDA = 1
[11-14_14:43:34:524] requestBaseBandVersion EC25AFFAR07A14M4G
[11-14_14:43:34:656] requestGetSIMStatus SIMStatus: SIM_READY
[11-14_14:43:34:689] requestGetProfile[1] my.apn.here ///0/IPV4
[11-14_14:43:34:689] requestSetProfile[1] ///0/IPV4
[11-14_14:43:34:754] requestRegistrationState2 MCC: 0, MNC: 0, PS: Detached, DataCap: UNKNOW
[11-14_14:43:34:788] requestQueryDataCall IPv4ConnectionStatus: DISCONNECTED
[11-14_14:43:34:788] ifconfig wwan0 0.0.0.0
[11-14_14:43:34:809] ifconfig wwan0 down
AT+COPS=?
ERROR
AT+QGMR
EC25AFFAR07A14M4G_01.003.01.003
AT+CGATT=1
ERROR
AT+CGATT?
+CGATT: 0
AT
AT+CFUN=0&AT+CFUN=1
ERROR
Could I get the most recent QFirehose as well?
EDIT: Found v 1.4.8, is this a successful flash?
[063.581]: upgrade progress 100% 248699580/248699580
[063.581]: send finished
[063.581]: <log value="Finished sector address 0"/>
[063.582]: <response value="ACK" rawmode="false" />
[063.582]: <power value="reset" />
[063.582]: <log value="Inside handlePower() - Requested POWER_RESET"/>
[063.583]: <response value="ACK" />
[064.584]: inf[0] ep_in -1/1024, errno = 71 (Protocol error)
[064.584]: qusb_noblock_read read=-1, errno: 71 (Protocol error)
[064.584]: qusb_noblock_read cur=0, min_size=1
[064.584]: THE TOTAL DOWNLOAD TIME IS 61.413 s
[064.584]: Upgrade module successfully.
Is this the wrong firmware?
at+cversion
VERSION: EC25AFFAR07A14M4G
Jun 28 2022 16:07:15
Authors: QCT
** In the prior version it was EC25AFA in the new version you sent, it’s EC25AFF
AT+CPIN?
Does the module read the SIM card properly?
Yes. SIM is ready state, but no attempt to associate with network.
AT+CFUN=0
AT+CFUN=1
AT+CPIN?
AT+CIMI
AT+QCFG=“band”
AT+QENG=“servingcell”
AT+QCFG=“nwscanmode”
AT+CEREG?
I receive errors for the first 2 commands as well as most of the others return an OK with no change. I pasted the response to a few above.
Please attach your log after execution
Need latest ec25-AU firmware
Hello, I need the firmware of this reference, could you share it with me, thanks
Please provide your current firmware version
AT+CGMR
I had exactly the same problem as @msignorello, and numerous others have reported, apparently, with EC25AFFAR07A14M4G_01.003.01.003. The EC25-AF is in a WG3526 and since I have two, I looked at the other (identical model, year, vendor labelling and batch as the first one I ‘upgraded’), because I forgot to note the original version, and AT+CGMR: EC25AFAR05A04M4G. No version number is displayed afterwards.
The modem went from working (with verizon in this case) to NO CARRIER, CME ERROR 30 issues.
I did a re-flash of the updated firmware, (although the prior flash was successful) and same issue. I did the various AT&F0 ‘resets’ etc to no effect, same error same behavior. Apparently this firmware is bad and I need one that actually works, to upgrade a EC25AFAR05A04M4G to current standards. I appreciate support’s efforts in getting firmware deployed, and I know you don’t write this stuff.
Quectel modems are buggy, but if you get them running and can work-around the bugs, they actually work OK for the money.
qfirehose flash utility for the modem: If there is a ROOTER (openwrt-based) firmware for your Quectel-containing router, there is likely a QFirehose compiled for your platform (e.g. MT7621 for the WG3526) in /usr/bin. Note it is named “QFirehose”, not “qfirehose”.
e.g.
QFirehose -f /tmp/firmwarefolder
to flash.
Disable modemmanager etc while flashing.
