Hardware = EC21A, country = USA.
I cannot create a PDP. This is using a SIM from ‘Red Pocket Mobile’ with a data only plan for the AT&T network. It gets on the network ok, and looking at the Red Pocket control panel the correct SIM, device ID and device type (Quectel EC21) are there. So the EC21 is talking with AT&T.
But AT+QIACT=1
fails. Not sure why yet.
ATI
EC21
Revision: EC21AFAR05A04M4G
AT+CSQ
+CSQ: 8,99
AT+QNVW=5280,0,"0102000000000000"
AT+QNVFW="/nv/item_files/modem/mmode/ue_usage_setting",01
AT+QNVFW="/nv/item_files/ims/IMS_enable",00
AT+QNVFW="/nv/item_files/modem/mmode/sms_only",01
AT+CGDCONT=1,"IPV4V6","broadband"
AT+CPIN?
+CPIN: READY
AT+CREG?
+CREG: 2,1,"xxxx","xxxxxxx",2
AT+CEREG?
+CEREG: 0,1
AT+COPS?
+COPS: 0,0,"Red Pocket",2
AT+QNWINFO
+QNWINFO: "HSPA+","xxxxxx","WCDMA 850",4385
AT+QICSGP=1
+QICSGP: 1,"broadband","","",0
AT+QIACT?
AT+QIACT=1
ERROR
AT+QIGETERROR
+QIGETERROR: 561,activate pdp context failed
The only thing I see out of place is that QNWINFO
returns WCDMA 850
. Not sure if this is valid for the LTE network as it appears to be 3G+ rather than LTE. Previously I had +QNWINFO: "HSPA+","xxxxxx","WCDMA 850",4385
which looked normal, but PDP creation did not work.
Edit: I forced the use of LTE rather than WCDMA, but same result
AT+QCFG="nwscanmode",3
AT+QNWINFO
+QNWINFO: "FDD LTE","310410","LTE BAND 2",850
Edit: Apparently the correct APN for Red Pocket AT&T is “ERESELLER”
AT+CGDCONT=1,"IPV4V6","ERESELLER"
AT+QNWINFO
AT+QIACT?
AT+QIACT=1
Then things get messy because I am not resetting the device before each test. But the PDP is being created and I get an IP address.
