I’m trying to change the configurations as you reported me.
As soon as I disable USB connection via ADB shell in linux, the connection is closed and I need to reboot the module.
Should I do the procedure using Debug UART port?
Moreover, if I want to enable the virtual com port by default where should I modify the kernel such that I can “compile” it and install into the module using “Quectel_Customer_FW_Download_Tool_V4.31”?
I was able to replicate your test using debug com port of the module. Very good!
I have only to setup by default the configuration in the kernel such that the module always export the virtual com port when connected to PC. In fact, if I reboot the module, then the virtual com port is not showed anymore.
Can you help me?
Hello I am looking for payment via paypal or other someone able to connect my iot docassion gps lte to a server in it is to install a
Quectel bg96 is another iot a quectel ec21-e because it is beyond my skills despite the hours I spend trying to learn how it works I will have to take control of my computer remotely this connect to iot remove the old give the client server is countering the new server data and that’s it.
I am available at any time, it is a serious request. I use google translation to discuss with you, so small errors can be contained in the discussion.
to pleasure.
My email address
