EC21-E debugging AT commands
Hello!
I have a EC21-E module.
I’m connected through the debug UART of the module to debug my application.
Is there a fast way to supply AT commands from within the quecopen system?
If so, which /dev/tty interface should I use?
I’ve seen other people online using an “at_com” binary but my firmware/quecopen SDK (EC21EFAR06A05M4G_OCPU_20.001.20.001_SDK) doesnt have it.
It’s a little bit outdated, maybe it’s in a newer version?
You can try the /dev/smd7 or /dev/smd8 for AT command.
Thanks! In the end I’ve used the following command:
atinout cmds.at /dev/smd9 -
