Hello I have an EC21, I cannot login to the ftps implicit server I created on centos, the error appears “522 data connections must be encrypted”
CONNECT: Client “xxx”
response: Client “xxx”, “220 (vsFTPd 3.0.2)”
command: Client “xxx”, "USER "
response: Client “xxx”, “331 Please specify the password.”
command: Client “xxx”, "PASS "
OK LOGIN: Client “xxx”
response: Client “xxx”, “230 Login successful.”
command: Client “xxx”, “SYST”
response: Client “xxx”, “215 UNIX Type: L8”
command: Client “xxx”, “CWD /”
response: Client “xxx”, “250 Directory successfully changed.”
command: Client “xxx”, “TYPE A”
response: Client “xxx”, “200 Switching to ASCII mode.”
command: Client “xxx”, “PASV”
response: Client “xxx”, “227 Entering Passive Mode (xxx).”
command: Client “xxx”, “LIST .”
Client “xxx”, “522 Data connections must be encrypted.”
configure my server:
pasv_enable=YES
pasv_address=3.0.175.207
pasv_min_port=60001
pasv_max_port=60010
force_dot_files=YES
use_localtime=YES
allow_writeable_chroot=YES
listen=YES
listen_ipv6=NO
pasv_addr_resolve=NO
rsa_cert_file=/var/key/vsftpd.crt
rsa_private_key_file=/var/key/vsftpd.key
ssl_enable=YES
allow_anon_ssl=NO
force_local_data_ssl=YES
force_local_logins_ssl=YES
ssl_tlsv1=YES
ssl_sslv2=NO
ssl_sslv3=NO
require_ssl_reuse=NO
ssl_ciphers=HIGH
user_sub_token=$USER
implicit_ssl=YES
listen_port=990
I have tried using winscp to the server successfully and the file is upload, download to the server.
And I also try sim module 7600ce-t that just login to the server, cannot perform other operations, often reports time out.
Pls help me. Thanks
