I have been working with quecopen SDK : EC20CEFILGR06A04M1G_OCPU_SDK. I am able to connect through AT port via dev/smd8 and am able send commands and get expected responses.
However, I am having trouble with examples provided. For instance, I am not able to establish connection with the socket example. Can someone explain me the flow. i.e. how to set APN via api.
I do not have any documentation. Please help me with that.
Thanks,
Jack
hi Jack
Sorry, for late reply;
For Quecopen related issues, I suggest you to find the local FAE for technical support; because open involves the allocation of internal resources of the module, the system stability needs professional technical support for you;
A series of check is needed before data call to make sure the module is in normal working state. The
specific steps are as follows:
- Connect PC to the MAIN UART port or the USB AT port of the module via the USB-serial line.
- Insert a SIM card and an antenna, and power on the module.
- Check the following status through API in sequence.
a) Test SIM card: QL_MCM_SIM_GetCardStatus ()
b) Detect signal strength: QL_MCM_NW_GetSignalStrength ()
c) Check network registration status: QL_MCM_NW_GetRegStatus()
d) Query operator: QL_MCM_NW_GetRegStatus()
e) Query network access technology: QL_MCM_NW_GetRegStatus()
f) Query call service status: QL_Data_Call_Init_Precondition()
In general, for multiplex data call application scenarios, it is necessary to set up special APNs to access
private network. The parameters of each APN can be queried and configured by Ql_Apn_Get() and
Ql_Apn_Set().
For details, please refer to
ql-ol-sdk/ql-ol-extsdk/exampel/data/example_apn_v2.c.
ql-ol-sdk/ql-ol-extsdk/example/data/example_data_call_v2.c
Other exampel and header as below:
| Header File |
Function |
Reference |
Document |
| ql_mcm_nw.h |
APIs of radio interface layer |
example/test_mcm_api |
| ql_mcm_gps.h |
APIs of location |
| example/gnss |
| ql_mcm_sms.h |
APIs of sms |
Quectel_EC2X&AG35-QuecOpen_SMS_Guide_Manual_V1.4_Preliminary.pdf |
| ql_mcm_sim.h |
APIs of sim |
Quectel_EC2X&AG35-QuecOpen_SIM_API_guide_manual_V1.1_Preliminary.pdf |
| ql_mcm_voice.h |
APIs of voice call |
| example/voice |
Quectel_EC2X&AG35-QuecOpen_VOICE_guide_manual_V1.0_Preliminary.pdf |
| ql_mcm_dm.h |
APIs of device management |
| ql_mcm_atc.h |
APIs of AT commands |
| ql_wwan_v2.h |
APIs of data call |
example/data |
Quectel_EC2X&AG35-QuecOpen_Data_Call_Application_Guide_V2.8_Preliminary.pdf |
| ql_wifi.h |
APIs of wifi |
example/wifi |
| ql_sleep_wakelock.h |
APIs of system sleep |
example/sleep_wakelock |
| ql_powerdown.h |
APIs of system halt |
example/powerdown |
| ql_dev.h |
APIs of device info |
| ql_gpio.h |
APIs of gpio |
example/gpio |
| ql_audio.h |
APIs of audio |
example/audio |
| ql_adc.h |
APIs of adc |
example/adc |
| ql_sgmii.h |
APIs of sgmii |
example/sgmii |
| ql_network.h |
APIs of network operation |
example/lan |
Quectel_EC2X&AG35-QuecOpen_LAN_DHCP_API_User_Guide_V1.0_Preliminary.pdf |
I have received the Quecopen SDK from quectel team but did not receive any documentation and my emails were not answered. Can you provide me with the necessary documents.
Thanks,
Jack
Can you tell me the website for downloading these documents?
Thanks,
helloworld
