Content:
Hello Quectel Support Team,
I am developing a VoIP gateway using the EC20-CE FAG module. I have encountered a critical UAC (USB Audio Class) playback issue on Linux and would like to request the latest firmware (e.g., R08A19 or newer) as mentioned in other related threads.
Hardware & Firmware:
Module: EC20CEFAG-512-SGNS
Revision: EC20CEFAGR08A03M4G
OS: Ubuntu 26.04 LTS (Linux Kernel 7.0), Windows 10/Server 2025
UAC Configuration:
AT+QCFG="usbcfg",0x2C7C,0x0125,1,1,1,1,1,0,1(UAC enabled) -
Voice Routing:
AT+QPCMV=1,2(UAC voice routing enabled, returns OK)
Issue Description:
On Windows: Playback through the “AC interface” (UAC) is extremely stable and quality is perfect. (Note: Capture has no level, but since Linux Capture works, the hardware is fine).
On Linux: Playback (host to module) starts normally, but gradually degrades (dropped frames, volume drops, crackling) and then goes completely silent within 15 seconds to 2 minutes.
Self-healing: Pausing the audio stream for a few seconds and resuming temporarily restores the sound, but it dies again shortly after.
No URCs or dmesg errors: During the death of the audio stream, the AT port receives no
+QPCMV: 0URC, anddmesgshows no USB or ALSA errors. The module silently stops consuming data.
Test Data & Evidence:
cat /proc/asound/card2/stream0shows:-
Playback: Endpoint 0x06 (6 OUT) (ADAPTIVE)
Capture: Endpoint 0x8a (10 IN) (ASYNC)
Rates: 8000, Data packet interval: 1000 us.
Tested with PipeWire (default desktop) and ALSA
hw:direct connection. -
Tried
speaker-test -D hw:CARD=Android,DEV=0 -p 32,-p 64, and-p 128to adjust buffer sizes (both low and high). All configurations eventually fail with the same symptom. -
Capture (network to host) works flawlessly on Linux (KDE level meter fluctuates normally), confirming the ASYNC IN endpoint is healthy.
Conclusion & Request:
It seems the module’s ADAPTIVE OUT endpoint has a firmware-level state machine issue (FIFO overflow/stall) when the host does not pace the isochronous packets exactly like usbaudio.sys on Windows. Since Linux snd-usb-audio relies on application-driven pacing, it triggers this bug.
Could you please provide the latest firmware package (R08A19+) which includes the “improved UAC and VoLTE” fixes? I am happy to flash it using QFlash and provide the test results back to the community.
You can send it to my forum registered email or via DM
Thank you for your time and support.
Best regards,
heaimi
