EC200UCNAA Module Stuck in "SPRD U2S Diag" Mode After QuecPython Update
Hello Team,
I am facing an issue with EC200UCNAA modules after updating firmware and running QuecPython scripts.
Issue Details:
Some modules are now stuck and only show the following port in Device Manager:
SPRD U2S Diag
Other ports such as AT port, NMEA port, and modem ports are not appearing.
Before this issue, the modules were working normally.
Observed Behavior:
  • SIM not detected & no network registration on affected modules
  • Modules only show Diag port
  • AT commands cannot be accessed
Troubleshooting Done:
:white_check_mark: Verified VDD_EXT = 1.8V
:white_check_mark: STATUS pin remains low
:white_check_mark: Tried pulling BOOT pin high (1.8V test)
:white_check_mark: Tried power cycling and USB re-plug
:cross_mark: No AT/USB ports — only DIAG
:cross_mark: Unable to enter fastboot mode
What I Need Help With:
Kindly guide me on:
  1. How to recover modules stuck in Diag-only mode
  2. Procedure/tool for re-flashing bootloader/firmware in DIAG mode
  3. Any known issues related to QuecPython update causing this behavior
Request:
If possible, please share:
  • Correct recovery steps
  • EC200UCNAA SDK
  • Required tools/software (QFlash, etc.)
  • Boot key/USB boot instructions
This issue is urgent for our development. Any help is greatly appreciated.
Thank you in advance!
