In Our Project Previously we were using 2g GSM Module and Now we want to switch to 4g module.
We are checking working of EC200UCN Module.
For Monitoring Call We are using command “AT+MORING” command which "Show State of Mobile Originated Call ". We have response as “MO RING” when call is alerted to dialed number.
We want to disconnect call after ring is alerted to dialed number.
I have tried to find Similar command in AT Command Manual of EC200U but i am unable.
For Detecting If Module is Ready to Send SMS we are using “SMS Ready” response.
Which is also not present in EC200U Module.
hi,
1、You can use ATH to hang up the phone
2、EC200U can send text messages normally, the SIM card initialization is completed, and the SMS service can be configured to receive and send text messages normally.
thanks.
ATH Command I already know But I want Ring Indication on Called Device so that after 5 ring i can disconnect call.
This We have already implemented Using simcon SIM800L with AT+MORING Command.
hi ,
I tested it locally with ec200u. It rings 7 times and then hangs up. The function is normal. After ringing once, a ring is reported. Can you send me your test process? Thank you.
[2023-11-30_14:13:02:941]atd15072713431
I just wanted to know if module supports “MO RING” to know that dialed numbers is alerted with ring and SMS Ready for knowing module is ready to receive messages.
By the way currently we have changed the module, now we are using BC660K-GL.
I want QuecOpen sdk for BC660K-GL module. Please help me.
