We are trying to interface a SPI based External NOR flash memory, datasheet attached) to EC200U. But as we are using the GNSS also we can’t use the Primary SPI pins that are (GPIOs 38,39,40,41). So, we have to use the secondary SPI pins which are (GPIOs 24,25,26,27). So, kindly provide us with the pin mapping of secondary SPI pins with (MISO, MOSI, CS, SCLK). EC200 pinout attached below.
Hi @IParth
I send it to you by message,pls chk.
Hi Iyman-Q I have the same query - Can i have the message / solution?
