Great, you have all the connection details from the carrier - address, mask, gateway and DNS.
You mean IP address will be auto assigned to any sim I connect ?
what about APN ? I need to add if I change the SIM ?
Please guide here!
If not this two utility then how should I proceed to connect my gateway to GSM/4G connection with ppp interface over this modem ?
Your modem receives an address for a duration of the session, your SIM is just a storage of your credentials.
Depending on your provider you may need to change or add APNs. Some providers can work with wrong APNs.
With the modem in ECM mode you only need a regular DHCP interface on the host side.
If you will send to the modem AT+QNETDEVCTL=3,1,0
once, it should connect automatically.
Status | unlock retries: sim-pin (10), sim-puk (10), sim-pin2 (10), sim-puk2 (10)
| state: registered
| power state: on
| access tech: lte
| signal quality: 100% (recent)
---------- got this in “mmcli”
