I am developing an IVR application using an EC200U-EU module with QuecPython.
Current firmware:
EC200UEUAAR03A04M08_OCPU_QPY
I need to detect incoming DTMF digits during an active voice call.
I tested:
AT+QTONEDET=?
and received:
+CME ERROR: 58
The QuecPython voiceCall API available on this firmware also does not provide an API/callback for receiving DTMF.
My questions are:
- Is incoming DTMF detection supported on EC200U-EU A04 with QuecPython?
- Is there another official firmware/build for
EC200UEUAAR03A04M08that enables DTMF detection? - Does the QuecOpen C SDK for EC200U-EU provide an API for incoming DTMF detection or DTMF callbacks?
- If yes, can the QuecOpen SDK be used with the current A04 firmware, or is a specific QuecOpen base firmware required?
- If the capability is available, could you please provide the appropriate SDK, firmware, or documentation?
The intended application is a simple VoLTE IVR where incoming DTMF digits are used to control GPIO outputs.
Thank you.
