An22
September 5, 2022, 7:56am
#1
I am working on DSSS applicaion in EC200U.
Slot one is working properly but facing issue in second sim slot netwrok refistration.
Attaching the logs,
9/5/2022 12:23:39.546 [RX] - ATI
EC200U
Revision: EC200UCNAAR02A10M08_BETA0505_DS
9/5/2022 12:39:06.651 [TX] - AT
9/5/2022 12:39:06.669 [RX] - AT
9/5/2022 12:39:10.988 [TX] - AT+QDSIMCFG="dsss",1
9/5/2022 12:39:10.997 [RX] - AT+QDSIMCFG="dsss",1
9/5/2022 12:39:14.325 [TX] - AT+QDSIM?
9/5/2022 12:39:14.339 [RX] - AT+QDSIM?
+QDSIM: 0
9/5/2022 12:39:17.350 [TX] - AT+CPIN?
9/5/2022 12:39:17.365 [RX] - AT+CPIN?
+CPIN: READY
9/5/2022 12:39:20.001 [TX] - AT+CREG?
9/5/2022 12:39:20.015 [RX] - AT+CREG?
+CREG: 0,2
9/5/2022 12:39:28.548 [TX] - AT+CREG?
9/5/2022 12:39:28.562 [RX] - AT+CREG?
+CREG: 0,1
9/5/2022 12:40:19.965 [RX] -
+QINDDS: SMS DONE
+QINDDS: PB DONE
9/5/2022 12:40:35.526 [TX] - AT
9/5/2022 12:40:35.540 [RX] - AT
9/5/2022 12:40:39.117 [TX] - AT+QDSIMCFG="dsss"
9/5/2022 12:40:39.131 [RX] - AT+QDSIMCFG="dsss"
+QDSIMCFG: "dsss",0
9/5/2022 12:40:40.833 [TX] - AT+QDSIMCFG="dsss",1
9/5/2022 12:40:40.847 [RX] - AT+QDSIMCFG="dsss",1
9/5/2022 12:40:42.849 [TX] - AT+QDSIMCFG="dsss"
9/5/2022 12:40:42.864 [RX] - AT+QDSIMCFG="dsss"
+QDSIMCFG: "dsss",1
9/5/2022 12:40:46.599 [TX] - AT+QDSIM?
9/5/2022 12:40:46.613 [RX] - AT+QDSIM?
+QDSIM: 0
9/5/2022 12:40:50.515 [TX] - AT+QDSIM=1
9/5/2022 12:40:50.529 [RX] - AT+QDSIM=1
9/5/2022 12:40:53.181 [TX] - AT+QDSIM?
9/5/2022 12:40:53.195 [RX] - AT+QDSIM?
+QDSIM: 1
9/5/2022 12:40:55.463 [TX] - AT+CPIN?
9/5/2022 12:40:55.477 [RX] - AT+CPIN?
+CPIN: READY
9/5/2022 12:41:01.626 [TX] - AT+CIMI
9/5/2022 12:41:01.640 [RX] - AT+CIMI
405857172225563
9/5/2022 12:41:04.063 [TX] - AT+CREG?
9/5/2022 12:41:04.077 [RX] - AT+CREG?
+CREG: 0,0
lyman-Q
December 6, 2022, 5:39am
#2
Hello, can you use AT+QDSPIN? Command to check the status of the card. Besides, I see that your firmware version is beta version, I will try to find the latest version. Please leave your email address if you need it.
An22
December 6, 2022, 8:29am
#3
Hi @lyman-Q
Thank you for your support.
I have try this AT+QDSPIN? command also but still not able to get it work.
Yes , i get beta version for dual sim application .
if you have latest firmware kindly please share it.
mail id : ashvin.makwana@optimized.solutions
Thanks & Regards,
Ashvin Makwana
lyman-Q
December 8, 2022, 5:29am
#4
Hi
I send the lastest firmware to you,please check,i hope it will useful.
An22
December 8, 2022, 8:01am
#5
lyman-Q:
lastest firmwa
Thanks, I have got shared firmware folder.
I will update here after testing.
Thank you,
Ashvin Makwana
lyman-Q
December 9, 2022, 1:47am
#6
OK, wish you all the best.
An22:
AT+QDSIM=1
I couldn’t access the second SIM.
ATI
EC200U
Revision: EC200UEUAAR02A07M08
AT+QDSIMCFG="dsss"
+QDSIMCFG: "dsss",1
AT+QDSIM?
+QDSIM: 0
AT+QDSIM=1
+CME ERROR: 4
Where can I download R02A10xx firmware?
how to install this firmware?
An22
February 13, 2023, 10:19am
#9
you can install or upgrade new firmware over USB connection. For this you have to set modem into firmware upgrade mode using boot pin of modem and QFlash Utility to upload required firmware.
can you explain me how to do this firmware upgradation in modem?
Thank In Advance
An22
February 13, 2023, 11:28am
#11
Follow the below step,
In your hardware design USB port is necessary to upgrade the firmware else it is not possible.
Check belowe image for referance.
Updating EC200U Firmware Over USB AT com port
if quectel usb driver is not available need to install in pc(Host) system.
Before powering up , connect USB_BOOT to 1.8 V [on pcb jumper].
Now power up the board over USB.
Check device manager for " SPRD U2S Diag " port.
it must be available, if not found check for driver update of newly arrive port.
open Qflash software and select firmware which is provided by quectel vendor to update in board.
select port from drop down list.
if everything ok , Press START & wait for PASS message for complete upgrade.
[QFlash Tools]
[Hardware Design File]
still I am not getting network after firmware update kindly guide me how get network in second sim slot after module power turn on
An22
February 15, 2023, 4:01am
#13
sstpl123:
it is sim operator issue.As per my last discussion with quectel support team, all sim is not supported in 2nd slot.
according to quectel airtel is supported and I tried with it but not getting network yet
