Hi!
I’m experiencing a weird condition using a EC200T-EU module. I’m using the modem with a custom apn sim but the modem keeps getting from the server side a “+QIURC: “pdpdeact”,1” error, causing the connection to go down in periods ranging between few seconds up to several minutes. Of course i immediatley thought the problem was on the sim’s provider side but i couldn’t find a mobile phone or a non-quectel modem that did the same condition, so now i’m considering it has something to do with the quectel module.
Before the AT logs i registered, some notes:
- it’s normal that the sim pings only the 172.16.0.30 ip and the public 8.8.8.8 one fails
- the private APN used is custom and works on the TIM network (italian provider)
- the signal level is relatively low but with the same module and using a different TIM sim it connects and work perfectly
- The logs are from a EC200T module but we’re having the same issue on EC21
at
at+cgsn865334046476211
at&v&C: 1
&D: 2
&F: 0
&W: 0
E: 0
Q: 0
V: 1
X: 4
Z: 0
S0: 0
S3: 13
S4: 10
S5: 8
S6: 2
S7: 0
S8: 2
S10: 15OK
atiQuectel
EC200T
Revision: EC200TEUHAR02A05M16OK
at+csq+CSQ: 13,99
at+qicsgp=1,1,“xxxxxxxxxx”,“yyyyyyyy”,“zzzzzzzzz”,3OK
at+qiact=1OK
at+qiact?+QIACT: 1,1,1,“192.168.161.65”
at+qping=1,“172.16.0.30”OK
+QPING: 0,“172.16.0.30”,32,775,124
+QPING: 559
+QPING: 0,“172.16.0.30”,32,430,124
+QPING: 0,“172.16.0.30”,32,0,124
+QPING: 0,4,3,1,0,775,401
at+qping=1,“8.8.8.8”OK
+QPING: 559
+QPING: 559
+QPING: 559
+QPING: 559
+QPING: 550
